I have an LG model #47LN5750, watched UTube video yesterday and followed procedure for troubleshooting I have audio and no video, I did the flashlight test and I can see the menu screen, I have 3 boards a power supply, main board, and t-con board if i'm right the back light controls are in the P.S. board will you correct me If I'm wrong and could you give me a price for a new P.S. board
if you dont have any clue,take it to someone that does or damage your tv
SOURCE: No back-light on LG LED TV
That means dead transformer supply chain. Replacing search not possible, donor Yes
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
SOURCE: LG 47LN5750 No picture
If you have backlights its not going to be the tcon for future reference. you have some shorted or open LEDs in the panel. Check the voltage going to the LED sets, should be 100 plus volts
