There is nothing you can do with this problem. As long as you’re disc are clean from scratches and finger print there’s nothing more you can do to player.
The hull is covered with plastic. Peel the plastic off, uncover the vents and it will stop overheating.
This could be so many things:
1. Loose or bad cable from the laser.
2. Bad laser.
3. Bad stepping motor
4. Bad motor control
5. Lubrication issue or rail alignment.
The only one you can control is #5. What is the model number?
SOURCE: Disc Incompatible
my friend u just clean the lense by cotton tips without applaying any liquid or spray air which is available in pressurised containers.I have the same DVD player with missing of IC no:104 in signal board which is placed under the lense mechanism,please I like to request u to send the IC number on following ID [email protected] or [email protected]
SOURCE: movie skips and freezes during play
This is a common problem on CD and DVD players.
Altini is correct to a point. You can try taking the top case off,
removing the DVD drive and taking the top off of the drive. Then use a
q-tip on the laser lense. I use a little squirt of windex on the q-tip.
Gently clean the lense even if it doesn't look dirty. Make sure you
very gently work the lense up and down through it's travel. This will
make sure no dust or dirt is interfering with the lense focusing.
Reassemble and try your movies again. This is a 50 50 proposition. If
you still have the same problem, the mechanism has likely gone bad.
Time for a new DVD player.
SOURCE: Blue-ray disc causing Sony blue-ray player to shutdown
No memory issue check on Sony's Website for Firmware update for your specific model and doenload and update your player
SOURCE: DVD player picture freezes
hi u can purchase a sony DVD lense cleaner which can make ur dvd player lense perfect for running various kind of dvd... pls rate me
SOURCE: insignia dvd player wont play some discs
How to unlock a dvd player Insignia NS-H2002-U for region free
Insignia NS-H2002-U
With disk In the player (must be allowed region on you dvd)
Press stop in the remote dvd control 2 times to have a dvd screen in your tv
Press 16719 in your remote no matter what appears in the screen, at the end the region menu will appear
Using down arrow go to region that you want, “0” is for region free.
Press ok and enjoy it.
If do not work, power of your dvd, turn on again, incert allowed dvd movie in your insignia dvd player, when start reading disk, press stop and the press setup in your remote control, set uo dvd screen appears, then press 16719 in your remote, region menu will appear and use down arrow to select your region code, zero is for all regions.
Enjoy it
Sounds like you have a dirty lens, try getting a DVD cleaner from your local electronic shop (Wal-Mart, Best Buy, etc...) this should fix the issues which you are having, hope this helps.
