Refrigerators Logo
Please DCF-500 compressor 1 new purchase - Refrigerators
2helpful
Could you please tell me, what does DCIM in my sony ipod mean? how can i use that or when do i use that? please
Yes, that is the access to you picture files.
From WIKI:
Design rule for Camera File system (DCF) is a JEITA specification (number CP-3461) which defines a file format and file system for digital cameras, including the directory structure, file naming method, character set, file format, and metadata format. It is currently the de facto industry standard for digital still cameras. The file format of DCF is based on the Exif 2.2 specification.
The latest version of the standard is v 2.3.
The filesystem in a digital camera contains a DCIM (Digital Camera images) directory which contains possibly multiple subdirectories with names such as "123ABCDE", which consist of a unique directory number (in the range 100...999) and five alphanumeric characters, which may be freely chosen and often refer to a camera maker. These directories contain files with names such as "ABCD1234.JPG", which consist of four alphanumeric characters (often "DSC_" or "IMG_"), followed by a number. The file extension is "JPG" for Exif files and "THM" for Exif files that represent thumbnails. Other file formats use different extensions. Multiple files sharing a number (even if the file extension or the four alphanumeric characters are different) are considered related and form a DCF object.
For example, the files on a Nikon D40 are arranged according to the above specification. Thus, a card formatted by the camera will have a partition named "NIKOND40", with a subdirectory named "DCIM". This directory contains a subdirectory named by default "100NCD40", in which images are stored. images are named "DSC_xxxx", where xxxx represents the file's sequential number.
As this is an industry standard, similar directory structures and naming procedures can be found in most digital cameras.
[edit] AccessCamera file systems can usually be accessed by directly mounting them via the USB mass storage device class protocol, which exposes the file layout, whether DCF compliant or otherwise. Alternatively, and independent of DCF, files may be accessed via the Picture Transfer Protocol, which provides an object-oriented view and need not expose the file layout.
The file system layout is often opaque to users, as images are copied onto a computer or printer and the application deals with layout
Apr 11, 2011 • Vacuums
3helpful
When I take my SD card out, it still says "DCF
well as long as it works when u put the sd card in then its all good right?
also
  1. DCF Full Error error message. The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You'll have to format the card with the Samsung camera. However, make sure you download any photos to your computer first.
How compressor will be installed technical information R-404 2ton reciprocating
1.Recover refrigerant from system
2.Remove suction and discharge lines
3.Remove electrical components
4.Remove old compressor
5.Install new compressor
6.Install electrical components
7.Install suction and liquid lines
8.Remove old drier and install new one
9.Connect gauges and evacuate from both high and low sides to at least 500 microns
10.Charge system and check for leaks
3helpful
Clicking sound for 5 or more minutes before motor comes on
That clicking sound is the compressor relay on the Control Board, trying to kick on the compressor. You cant do much about this problem but wait till the compressor no longer wants to run. Then you might aswell purchase a new refrigerator because it would cost around $500-$600 to replace a compressor.
I need to know what filters to purchase for this model
Style DCF-14-62731 is the model of the filter you need.
20helpful
6answers
DCF Full Error
I have got a Samsung ES30 Digital camera .Everytime i turn it on it always says DCF Full Error ' which i have no idea means .Please help???
Can images recorded by another digital camera be played on this camera?
It is possible if they support the Exif data (image data) based on DCF. However, they may not be played back, or played back as thumbnails depending on the file format, image size or data configuration in a file. Also, the audio files attached with images cannot be played on this camera. DCF = abbreviated expressions of a standard for aim at the compatibility in files between the related devices such as digital cameras. Please refer to the instruction manual of your camera (main specification - image file format) to confirm if the camera is compliant to DCF or not.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
