It sounds like you are having an issue with setting the time on your Ott light. Here are a few suggestions that may help you resolve the problem:
Check the owner's manual for your Ott light. It should have instructions on how to set the time and troubleshooting tips for common issues.
Make sure that the light is plugged in and the power is turned on. If the light is not receiving power, the time cannot be set.
Check the batteries in the remote control. If the batteries are low or dead, the remote may not be able to communicate with the light and the time cannot be set.
Make sure that you are pressing the correct button on the remote to set the time. Some Ott lights may use a different button or sequence of buttons to set the time.
If the light is still not responding to the remote control, try resetting the light by unplugging it and then plugging it back in. This may reset the light and allow you to set the time.
If you have tried these steps and are still having trouble setting the time on your Ott light, you may need to contact the manufacturer or a customer service representative for further assistance. They may be able to provide additional troubleshooting tips or repair the light if it is experiencing a hardware issue.
check and replace bulb first, if not that then most likely a ballast problem, which sends a boost of the correct amount of power to ignite the bulb then lessens the flow of power it needs to stay lit.
If you haven't used it in a while or if it is in a cold area, it may be a warmup issue, try turning it on a waiting a few seconds, even in the best time there is a delay. You are correct to expect the bulb to last a long time most Ott bulbs do last!
Have you replaced the ballast or did you just replace the capacitor? If you did not replace the ballast I would start there. Also if you have a multimeter check your bulb for continuity you may have gotten a bad bulb.
Depending on lamp the bulb is approximately a 1/8 turn with a slight push toward the base to release the bulb, If you have not purchased the replacement bulb take the old one with you, some "high end" lamp stores will have replacements, if not the website will help. Good Luck!
Douglas
