Washing Machines Logo
H
Harlan Foskett Posted on Feb 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you get the agitator off of an amana ntw4605ewo washer. I already have the dust cap and bolt removed.
Frank
Level 2:
Novelist:
  • Expert 90 Answers
  • Posted on Feb 07, 2019
 Frank
Expert
Level 2:
Novelist:
Answers
90
Questions
0
Helped
37888
Points
249
Once the bolt is removed, it should be able to just pull up. It may be tough but grab it from the base and pull up with some force. Carefull not to hit your face once you free it up.
5 Related Answers
Anonymous
  • 126 Answers
  • Posted on Nov 22, 2007
SOURCE: Kenmore 70 washer
if its that old your lucky you got the agitator off! there .should be a spline on top of transmission shaft. the agitator will slide down on it. your problem will probably be the wig-wah located on top of trans.take the back off the washer you will see 2 solenoids this is the part
Anonymous
  • Posted on Oct 14, 2008
SOURCE: GE washer WWSR3090T6WW
I DONT KNOW HOW TO REMOVE MY AGITATOR PARTS TO PUT IN THE NYLON COUPLING I GOT THE TOP PART OFF BUT THATS THE ONLY PART COMES OFF
Quantum Flux
  • 30 Answers
  • Posted on Jan 21, 2009
SOURCE: Amana Washer model number LWD27AW
Try pulling the knob out & rotating counter-clockwise to unscrew it.
Fred Estrada
  • 5 Answers
  • Posted on Mar 13, 2009
SOURCE: I've had an Amana Washer model ALW880QAW for about
I couldn't wait for a rely on my posted question on March 6,2009. I was able to ask around to figure out how to clean this up. This Amana washer model has an agitator that is just clipped on. I just got my fingers underneath the agitator and pulled it off. After getting the agitator off, I was able to clean all of the old built up detergent and fabric softner with some old fashion scrubbing. Then I used some CLR to get what ever I missed. I pushed the agitator back until it clicked back into place and ran one washing cylce to clean things up.....Works great....No more old clumpy stuff showing up in the wash....
Anonymous
  • 84 Answers
  • Posted on Jan 17, 2010
SOURCE: Amana washer won't agitate when full with laundry
The belt is probably worn down. Replace it.
How to tighten agitator bolt on amana nav8800e
Remove the fabric softener cap on the agitator to access the 7/16 bolt.
1helpful
2008 model number not found on selection list, model #nfw7200tw washer did not spin and drain out dirty water and complete rinse and spin dry cycle, tried to reset by manual instructions and it would...
Hi
It seems that something is stuck and you'll have to remove the agitator to clean it. If this is an old style washer, then it should have a bolt under the cap that must be removed to remove the agitator, then grab hold of the agitator and lift up. If it's a not too old then the agitator just pulls out, remove cap, if no bolt, just grab hold and lift it up hard... see the picture. Hope this helps...please post back for further assistance.
Daniel
4helpful
2answers
How do you remove the agitator on amana washer model lwa30aw
Unplug the Amana washing machine from the wall outlet, and open the lid. Pull the liquid fabric softener dispenser straight off of the top of the agitator. Some Maytag washers require the use of a flat head screwdriver inserted between the dispenser and the top of the agitator. Twist the handle of the screwdriver to pop the dispenser off of the agitator.
Remove the barrier cap inside the agitator using your hands. Pull the barrier cap straight out of the agitator. There is an O-ring that attaches to the outside of the barrier cap. If it did not come out with the cap, pull the O-ring out of the center of the agitator.
Remove the bolt securing the agitator to the drive bell with the socket wrench. The bolt is inside the center of the agitator.
Place your fingers in between the bottom of the agitator and the tub. Lift straight up to remove the agitator from the tub. Keep your head out of the way in case the agitator is stuck and unexpectedly releases. If necessary, use agitator hooks. Insert them under the agitator and push down on the hooks to release the agitator.
5helpful
3answers
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Agitator wont work, quiet hum and smell
Noises
Often something works it's way into the pump and makes a clicking or scraping noise. Another bad spot on this washer is the snubber ring that sits between the base and the drive unit.
1) Whirlpool, Inglis, (some) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1picture2.
(2) Whirlpool, Inglis, (some) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator.
4helpful
I've had an Amana Washer model ALW880QAW for about 6 yrs. Recently I've noticed old clumps of old detergent and fabric softener in the wash. I've already cleaned the fabric softener dispenser but the...
3helpful
2answers
Agitator Removal
Most agitators also have an air gap cap underneath the fabric softener cap as well. This is to prevent water from rising inside the agitator and getting to the drum bearings. Look closely under the fabric softener cap to see if there is another cap that you might have to remove. You can usually use a small flat tip screwdriver to lift the cap off. You will need a socket (with extender) and ratchet to reach the mounting bolt. As you loosen the bolt, you will need to hold on to the base of the agitator at the same time to keep it from turning. Now, not knowing what your agitator looks like, it may or may not have this set up (just a thought for you try). If there is no mounting bolt of any kind as you say, the type of agitator you may have is held on by plastic grips that snap on to a mounting hub under the base. Unfortunately there is no easy way I know of besides lifting straight out. You may have to rock it side to side a little while pulling up to get the clips to release. Normally, the problem encountered with this type of agitator is the clips wear out and no longer grip and it keeps falling off. Why do you need to remove the agitator? Just wondering because you didn't mention any problems. Good luck to you. I hope this helps.
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
