20 Most Recent Amana NTW4600YQ Questions & Answers
manual
NTW4600YQ Manual
Amana NTW4600YQUploaded on Mar 20, 2017
Amana ntw4600yq, continuously drains as it fills
Tip up the machine & look for a diagnostic servicemanual taped inside up high in a bag
9/5/2013 4:46:09 AM • Amana NTW4600YQ • Answered on Sep 05, 2013
0answers
Amana washer
Be the first to answer 4/30/2013 7:26:06 PM • Amana NTW4600YQ • Posted on Apr 30, 2013Be the first to answer
Amana washing machine lid is locked and it's like it's not getting power
If your Amana washing machine lid is locked and it seems like it's not getting power, there are several steps you can take to troubleshoot the issue. Follow these steps to identify and potentially resolve the problem:
3/7/2024 7:01:50 AM • Amana Washing... • Answered on Mar 07, 2024
Will an Amana washing machine, power up without the inlet valve hooked up
Probably but not advised.
3/6/2024 8:35:39 AM • Amana Washing... • Answered on Mar 06, 2024
Amana washer. Why is it acting up?
Question edited for clarity, 'Amanda' to 'Amana'. Question moved to maker category. It is sensing, and that you have something that needs a 'Delicate' setting, or a 'Woollens' setting. It provides water and very little agitation that might damage or stretch the clothes. Read the manual. Google Amana (model) manual ..
10/20/2023 4:58:36 PM • Amana Washing... • Answered on Oct 20, 2023
How can I clean my Drain filter on an Amana front load washer, model NFW5800HW3. There is no opening at the bottom of the washer. It's a full sized front panel.
The pump and filter appear to be hidden behind the front kick stripClick the arrow button to the right and go to 'Water System Parts'. The pump and filter are shown.https://www.searspartsdirect.com/model/4e6ciymtfs-001268/amana-nfw5800hw3-washer-partshttps://producthelp.amanacanada.ca/Laundry/Washers/Product_Info/Washer_Cleaning_and_Care/Cleaning_the_Pump_Filter_-_Front_Load_Washerhttps://www.google.com/search?q=Amana+front+load+washer%2C+NFW5800HW3+drain+filter..
10/3/2023 9:43:11 PM • Amana Washing... • Answered on Oct 03, 2023
I have an Amana Tandem 7300 Front Load Washing Machine.
Fiona, could it be that your'e using Liquid color-safe bleach as it is thicker than chlorine bleach and will not dispense properly from the chlorine bleach dispenser? And did you Remove the inserts from the drawer. The inserts are the detergent selector and covers of the softener and bleach dispenser.. and clean and replace them? Tis really hard not being there and being able to see the unit. But thought I'd give you these suggestions. Best to you.
8/15/2023 5:33:37 PM • Amana Washing... • Answered on Aug 15, 2023
Amana washer not draining properly
Washer will not drain: The drain water pump is the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure to check the pump to be sure a small object like clothing or similar has not lodged itself inside of it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Read more:  HYPERLINK "http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/" \l "ixzz3X2LbXMWJ" http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ The washing machine drain hose is where the water flows through to get the water out. If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the water from the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it The water pump belt (to drain out the water) may have broke or become frayed or loose. If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing the NO DRAIN issue and remove and replace if needed. If the lid switch is not working as required it will cause your washer to not drain (and many other problems). This may be unlikely as a bad lid switch will usually cause your washer to also not agitate or spin. However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuity My advice is free cuz God is good! washer-fills-and-drains-at-same-time-undefined-undefined-0_1.jpg water pump clogged washer 2-undefined-undefined-1.jpg water pump hose washer clogged washer hose1-undefined-undefined-2_2.jpg water pump sump dirty-undefined-undefined-3.jpg water pump2-undefined-undefined-4_1.jpg water pump good washingmachinepumps-undefined-undefined-5_0.jpg
7/22/2023 8:01:54 PM • Amana Washing... • Answered on Jul 22, 2023
Amana washer won't continuously fill the basin with water.
Laundry Washer or Dishwasher? If it is a dishwasher, it sounds like the Flood Sensor is stopping the cycle. There is a tray between the floor and the underside of the basin. If it is a Dishwasher, you just need to find the leak and fix it. For a Laundry washer, it is a problem with the control board and needs professional diagnosis and repair.
4/7/2023 6:34:51 PM • Amana Washing... • Answered on Apr 07, 2023
Amana washer will fill with water but then will make a constant clicking noise.
Culd you please give us a Model Number.
2/27/2023 11:20:11 PM • Amana Washing... • Answered on Feb 27, 2023
Amana lwa40aw noise during spin cycle
It's possible that the loud and fast clicking noise is being caused by the driven wheel skipping, which could indicate a problem with the transmission or clutch assembly. The motor speed at spin cycle initiation could also be related to these components. One possibility is that the clutch is worn and not engaging properly, which could cause the driven wheel to skip and make a clicking noise. Another possibility is that the transmission is worn or damaged, which could also cause these symptoms. It's also possible that the motor speed control is malfunctioning, which could cause the motor to run at an incorrect speed during the spin cycle. This could contribute to the belt wear issue you experienced. I would recommend contacting a professional appliance repair technician to diagnose and repair the issue, as it may require disassembly of the machine and specialized tools to properly diagnose and fix.
2/26/2023 5:14:36 AM • Amana Washing... • Answered on Feb 26, 2023
What is the capacity of top load amana ntw4516fw
3.5 cubic ft. here is a link to manual copy and paste https://www.manua.ls/amana/ntw4516fw/manual ..
2/22/2023 3:04:45 PM • Amana Washing... • Answered on Feb 22, 2023
My Amana works fine. Then when it gets to rinse it won't advance and the rinse just keeps blinking
It sounds like there may be an issue with the remote control you are using for your Polaroid TV. If the remote is able to turn the TV on and off, but cannot change channels or scan for antenna channels, it may be a problem with the remote's programming or compatibility with the TV. One solution to try is to reprogram the remote to work with the TV. The instructions for doing this can usually be found in the user manual for the remote or on the manufacturer's website. If that doesn't work, you can also try using a different remote control to see if that resolves the issue. If the problem persists, it may be a problem with the TV itself and you may need to contact the manufacturer for further assistance.
1/17/2023 7:14:19 PM • Amana Washing... • Answered on Jan 17, 2023
Amana Washing Machine Fault Code Help?
It sounds like an inlet water valve issue due to the humming. The solenoid isn't opening the valve fully and that makes them hum.
1/15/2023 10:58:03 PM • Amana Washing... • Answered on Jan 15, 2023
Amana NTW4600YQ Logo
6 questions posted
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Washing Machines
Most Popular Question
amana washer just finished load put in
  • Washing Machines
