Please help me to the queries.1. Should I need to replace all the three strips.2. The hard plastic material which is placed in the front of the led is available in the market.3 What glue should be used to stick the glass type material which comes over each LED bulb.4 What are the range of voltages comes in the line connected to the led from power supply board.Hope your valuable support, I like to post more queries
SOURCE: philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
SOURCE: No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
SOURCE: I need a replacement screen and i'm not sure which cffl/backlight to order
Here are the eBay search results for your exact system model -
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+L355D-S7809+screen&_sacat=0
SOURCE: LG Washer wont start, no power
I HAVE A BEKO 42WLH530HID TV, AND WHEN I TURN IT ON THE STANDBY LIGHT COMES ON BUT NO PICTURE OR SOUND, I KNOW ITS 1, OFF 3 CIRCUT BOARDS BUT DON,T KNOW WHICH ONE, CAN ANYONE HELP ?
SOURCE: Samsung led tv - turns on,audio ok, no video, backlight on
Sounds like T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Testimonial: "I have already replaced T-con board. here is what happens. initial tv had blank screen , with audio. and back light on. so I ordered T-con board and replaced it but now with new T-con board connected backlight is flickering like a strobe light. and I have tried with 2 different lvds cables. same result of flickering."
