Dryers Logo
Tracey Davidge Posted on Jan 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Affinity. Why does it run for 2 seconds, then stop and display PAUSE?
I cleaned all lint and there appears to be no blockages
Don A
Level 3:
  • Frigidaire Master 4,499 Answers
  • Posted on Sep 19, 2020
Don A
Frigidaire Master
Level 3:
Answers
4499
Questions
5
Helped
1337623
Points
25829
The fault often lies with the motor relay because the motor relay should keep the dryer running after you release the push-to-start switch.
The following page has a link to a video providing a tip to restarting the dryer. That said, the troubleshooting page points out that door latch problems can also be a cause of stoppages.
https://www.searspartsdirect.com/diy/symptom/dryer-repair/1234594/starts-then-stops/dryel09
5 Related Answers
Anonymous
  • Posted on Jun 19, 2008
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Anonymous
  • 639 Answers
  • Posted on Aug 25, 2008
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Feb 18, 2009
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jun 09, 2009
SOURCE: how to replace fuse dryer frigidaire affinity
If it is like any other frigidaire dryer it is mounted on the upper right hand corner of the rear bulkhead.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • 1554 Answers
  • Posted on Mar 07, 2011
SOURCE: I have a Frigidaire Affinity Clothes dryer
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
My Frigidaire Affinity washer stopped working in middle of cycle and shows PAU code.
'power strip'!! You can't run a washing machine from a power strip! It pulls far to many amps. Plug into a wall socket on its own.
PAU Error. The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display.
My Frigidaire Affinity Has a Pause Error ' Hunker
https://www.google.com/search?q=Frigidaire+Affinity+washer+PAU+code
Why does my frigidaire affinity front load washer model FAFS4272LWO beep every 15 minutes when it is not running?
Bring the unit out of sleep by pressing any button, wait about 5 seconds and the press AND HOLD start/pause and CANCEL an E followed by numbers should appear in the display. Tell us what those numbers are..
Frigidaire Affinity ATF6700FS2 pauses with every load
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Trouble code e20
Water not draining fast enough. Try holding the Start/Pause and Cancel key together for 3 seconds. The Door Lock, Wash, Rinse and Final Spin LED’s should light. Any error codes should be displayed when pressing the Start/Pause and Cancel keys.
Remove the bottom front panel. This can be done from the rear of the machine by unscrewing the 2 securing screws. The pump sits on the right side. Disconnect the hoses and clean them. Make sure to clean the pump impeller out as well.
The washer is stuck in pause mode. How do I get
Control Lock To avoid having someone accidentally start or stop the washer, press Options and Select at the same time and hold for 10 seconds until “LOC” is displayed alternately with the estimated cycle time. To unlock the controls, press Options and Select at the same time and hold 10 seconds until ”LOC” is no longer displayed.
4helpful
Won't wash
press the pause and stop button at the same time it will give u a code
1helpful
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
11helpful
5answers
GE WSSH300G0WW front load washer
Had same problem with GE wssh300 front load washer. Removed two screws from front bottom panel (under washer front). Pulled off panel, loosened screw from a seal ring on the rubber flex hose going to a 4" square plastic housing. Reached down inside and found a ton of lint (probaby a 2" balls worth) jamming outlet. Removed lint an works geat. Very easy to do by tilting front of washer up and putting supports under front to keep elevated. Be careful to make sure supports are sturdy washer can't dop when servicing.
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
