After i close dryer door and push off button it goes off but i can walk by it later and the lights are back on
Check Ebay for a control panel
https://www.ebay.com/itm/Used-Maytag-Neptune-Mother-Control-Board-/183617833971
This is usually an indication that the control board has failed. The part is no longer made, if you cannot find someone to repair the control board at the component level, it is time to replace the whole dryer.
SOURCE: Whirlpool Gold Dryer
You will need a volt Volt-Ohm (VOM) reader to fix this problem.
This doesn't rquire sound technical knowledge for this but you should be good at following some instructions.
This could be the effect of a number of problems. Here's a list of things to check and details on how to do it.
SOURCE: when you push the 4
a lot of 4wd you have to back up for a few feet to disengage the hubs after you tourn them back to 2wd
SOURCE: Door opens alittle then closes but not back all the way
If you have a Chraftsman/Liftmaster:
1.Check to see if the door is running correctly.
A. Run the door down and pull the emergency release. See if the door will run easily by itself.
1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
B. If the door runs fine then check the up and down force on your operator (the box that hangs from the ceiling and reads Craftsman). If the light(s) on your operator go from front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
C. If this does not solve your problem the top bushing could be going out of your operator. Open the case and see if a lot of black filings are on the top of the big gear. If so the gear assy. will have to be replaced part # 41C4220A
SOURCE: My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
SOURCE: dryer stops when I release push to start button
Timer may need to be replaced. You can test it with an ohmmeter or test light.
You can do the same with the push button. If you have more problems, then the main control could be faulty
