My Samsung, Diamond Drum, Top loader washing machine, WA13V9 does not fill with water. I replaced the hot and cold water inlet valves and the water pressure switch. Please help.
Generally speaking, In the top control head of most washing machines, there is a water level sensor that tells the machine when the drum has enough water in it and when to start the wash cycle according to what size load it is set for. In the older washers, it was basically like a barometric pressure sensor and had a clear plastic hose connected to it. When the water in the drum put sufficient pressure on the air in the hose, it would activate the switch and start the control timer, shutting of the water and starting the wash cycle. If your washer is new enough to show error codes, it may have some other version of this sensor but it will have to have something to say when enough is enough. Look in the control head on top. Good luck.
