SOURCE: reset older analog tv
Without the original remote, sorry none. You could try pressing on any of the buttons or a combination while plugging in the unit but that is no guarantee it will reset (fully). With your indulgence, I took the liberty of checking your other posts here and here. It would seem that your original concern is that although the TV would appear to be switching to the lower channels (Ch 2-6), the TV programs on those channels would not be displayed. If yes, then I am inclined to think that there is a hardware fault internal to the TV. This would be the tuner block. The reset, even if successful, would not correct this error.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
SOURCE: I cant find remote for 52" Bravia tv. Can I turn
Yes, you can turn it On-Off by pressing power button on side of tv.
Required tv remote for KDL-52W4100 is available at Remotes.com
Hope these info will help you.
Thanks.
SOURCE: panasonic model ct-27g14a tv is
Is there a menu button on the front of the tv? If so press the menu button and look for options in menu mode.
SOURCE: Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
SOURCE: Can I reset my factory
Hard to do without a remote. The remote for just about any Sony TV will work. Look on ebay, also do a web search for replacement remotes, lots of places sell them.
