20 Most Recent
Sony Bravia KDL-46V4100 46 in. LCD HDTV Questions & Answers
My Sony Bravia tv screen
If you haven't done so already, check that the cable between your tv and digital cable box(probably HDMI) is secure at both ends. If it is, try a different cable and/or different port on your tv if you have more than one. If the issue is still there after you've tried these options it's most likely an issue with either the digital box or tv. I would contact manufacturer at this stage for advise and possible replacement of tv or box if they are under warranty.
Hope this helps.
Scrambled LCD tv picture
I would think its a T-con bard fault its the main board for the screen over time they ware out from heat. this control the picture for the screen. they can go in many ways, black screen mixed or shadows even star screen and scramble type screen. and white lines and even half working only.
Sony kdl-46v4100 red light blinks 6 times please help
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
How do I reset my TV?
Hi
please open the MANU & then go setting where the factory rest is available so select the factory reset
thanks
How do I get Netflix on my Sony tv
You used to be able to stream Netflix on this model with the Bravia Internet Video feature. (BIV) Unfortunately this feature is no longer supported. In order to get your Netflix now, you will need a Roku box or a Netflix thumb drive (fire stick). I hope this helps.
Flickering screen
Two models of the 46 inch Sony Bravia have a screen flicker problem. On my 2008 model, starting from cold, it lasts for 5-10 min, on LHS of screen. The Telefix tech who visited said this is common with these models (46in only), a new panel is needed. Sony provides warranty on this fault for 3 yrs, so you do not need extended warranty to claim. Discuss your case with Sony or Telefix.
