SOURCE: Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
SOURCE: Keyboard letters wont work but only top row Of numbers
On a notebook computer, there is a FN key that when pressed with the appropriate special function key will disable the normal keyboard and enable the alternate letters (printed in a different color) on your keyboard.
Unfortunately, I can't remember which special function key that is--but the icon on it should give you a clue.
SOURCE: How do I enter the number
Brother's documentation is non-intuitive. Pressing the ' 0 ' key shows a ' * ', but it actually is accepted as a 0 and moves to the next character entry position. Just take it on faith that it enters a 0 when it shows * when entering the wireless key.
SOURCE: code for soniq smart tv for remote control
038,029,036,022,055. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
This unit provided with the following SERVICE MODES so you can repair, examine and adjust easily.
To enter the Service Mode, press both set key and remote control key for more than 1 second.
Then set volume to minimum and press "0" digit on the remote control to unlock V-Chip and to set a new password.
From this proceedings, you can know that, without its original remote control, the set cannot be unlocked. Try to get it from the nearest Duraband authorised service center or from any electronic spare part shops at your town. OK.
ervice mode do the following>
