I can not contact him at either phone number I have for him and 480/500/1812 has blocked my number. I paid 500 cash and i do have a receipt and a 7 yr. warranty . Can you help me with this issue. MY name and number is John Foster 623/229/5461
SOURCE: Leaky H3
you need to check and see if there is any debris blocking the drain tubes for the sun roof. If not then you need to follow the tubes and look for kinks or other reasons why its not able to drain off quickly.
SOURCE: rain water leaks from overhead console (No sunroof)
common problem with these roof racks check for loose bolts holding it on also there are inserts pressed into your roof under the roof rack these threaded insrts tend to come loose or get pulled out use silocone sealant around every bolt and insert.
SOURCE: i have gmc yukon when it rain my sun roof leak
I also have a sunroof that leaks on a 2002 Yukon. It is a factory sunroof with a cracked seal. Where can I get a new seal?
SOURCE: 08 Impala - Check engine lite on - Large Evap leak detected
If it is missing or not running perfectly you can damage the Oxygen sensors or the catalytic converter. If it is running perfectly then more than likely no damage will be done, but you still need to have it looked at by a professional with the proper tools and skill to diagnosis the problem and not just throw parts at it. The PCM and catalytic converter are covered by an 8 year 80,000 mile warranty whichever comes first. To know if your defect is covered which is highly unlikely, you need to talk to your local GM dealer.
Testimonial: "Appreciate the help. It really was helpful."
