If your QN75Q60TBFXZA screen keeps flicking and cycling, it could be caused by a few different issues, even if you already changed out the CPU board:
- Check the power cable to ensure that it is securely plugged in and that the outlet is working properly.
- Check the cable connections on the back of the TV to ensure that they are all securely plugged in.
- Check the power supply to ensure that it is functioning properly. If the power supply is faulty, it can cause the screen to flicker and cycle.
- Check the main board to ensure that it is functioning properly. If the main board is faulty, it can cause the screen to flicker and cycle.
- Check the power supply cable connection to the main board. If the cable is loose, damaged or not properly connected, it could be causing the issue.
- If the problem persists, consider contacting Samsung customer service or a technician for further assistance.
It's important to note that screen flickering and cycling can be caused by a malfunction or damage in the power supply, the main board or even the backlight. It's also important to check that all the connections are secure and that no damage has been made to the cable or the board during the repair process.
