Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the sites linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
{View the site in web view by Mobile or by a desktop to see the search box. Mobile view has no search box.}/
SOURCE: Toshiba Satellite 1135-S125 front LED indicators gone weird
Hi The strange operation of those LED's is most probably an error mode indicator. If a laptop fails to power on corectly it will use those LED's, lighting in a specific pattern to signal the error. That's an example. In your case something was damaged in some way because the error code indicator is still acting like there is an error. You may try to reset the BIOS to factory defaults (small chances that this will work) and leave the laptop unpowered for about 1 day. If the problem is still there you will need to have it fixed in a service center. By comparing the LED lighting pattern with information from the Toshiba service catalogs they will be able to tell you what kind of error had happen for wich the LED's to light in this manner. Sorry for my bad english, I live in a non-english speaking country. Good luck and don't forget to rate any answer received from this site.
SOURCE: Toshiba Satellite A105
The most common problem on these units is the ac connector solder joints break away from the motherboard. If you're sure the ac adapter is working, and the correct one, and it's not charging the battery (assuming the battery is good), it's most likely the problem. They don't have to appear loose to be loose.
Otherwise, it's motherboard time, or a loose screw, etc has caused a dead short on the board.
Good luck, if you have additional info, let me know.
SOURCE: Doesn't power on - Amber LED Blinking
Here's how I fixed mine...
Look inside the back of the TV just above the power cord - there are two small LEDs, one green and one yellow (no need to open the case - you can see them through the cooling slots). In my case, the green LED would light for a few moments after plugging the TV in, then the yellow one would light and stay lit.
Go to the Toshiba site and download the latest firmware upgrade.
Copy the firmward upgrade to a SD memory card using your PC (SDHC cards larger than 2GB don't appear to be supported by the TV, so use a smaller one). I copied *both* the zip file as downloaded from Toshiba, and the contents of the zip file. That is, I expanded the zip file and copied the contents to the SD card as well.
There's a metal cover over the SD card slot on the back of the TV. Remove it (a single screw)...at one point, Toshiba has directions on the firmware download web site.
Unplug the TV and insert the SD card. Plug in the TV again, and in my case, those little LEDs stayed green. I saw none of the instructions on the TV screen - rather I just let it sit for about 10 minutes, then I unplugged the TV, removed the SD card, and plugged the TV in again. Viola - the TV works.
I'm thinking perhaps Toshiba uses a type of memory that requires battery backup, and if the TV is unplugged for an extended period of time, it's necessary to re-flash it.
SOURCE: Dell Dimension 5100 will not power up. Was
Have you checked your monitor? Try your monitor on another PC and check it is OK. Once you change the MB battery you effectively "Kill" the PC, as all the settings in the BIOS are removed and must be reprogrammed. You must enter the BIOS, and select "Default" setup and then reboot, you must do this regardless of what else is done first.(A bit hard when you can't see anything" You say... "tried different power switch and ribbon cable connector" (sic) exactly what "Ribbon cable/Power switch"? Anyway as said check monitor, if it is OK, we will proceed from there, then, you must check your video card, test it in another machine, if possible, to see if thats OK, if it is OK, then it is now likely that you may have a Mother board problem. If you can, try another Video card to see if you get Video on screen. see we need to establish "Known Good" items, once we know whats what, we can then go on. Now if any of these things tested are faulty, Monitor, Video card, obviously replace them, however IF they are NOT faulty, as related it may be the Motherboard, Remove the RAM, and see if anything is on screen? If yes, replace RAM, If still NO, then take any cards out, and check, if then OK, replace cards one by one until you get to the one that stops it, there is your problem, replace it. All we are trying to do is get anything on the screen, if we do, then you must redo the BIOS, as related before. Now if you get it going it still may not boot through to windows desktop, if this is the case, after you boot press F8 and select safe mode, when you get asked if you want safe mode or system restore, choose system restore and choose a date before you had a problem that should get you back. You just have to logically work through, until you find the faulty "bit" and replace it.
Testimonial: "Thanks for the confirmation!"
SOURCE: Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
