Before you start looking for spark try to clean the main jet in the carburetor. !. Drop the float bowl.insert a screwdriver in the tube in the bottom of the carburetor and unscrew the main jet with it removed clean it with a brass brush and carburetor cleaner. Make sure all ports are open. reinsert and attach float bowl. enable gas flow and try to start. if it still fails then investigate the spark issue. Remove the plug and with the spark plug wire attached reduce lighting , place spark plug on engine block and pull starter with the on off switch on, watch plug for spark. If no spark its either the plug or coil/ the plug is easier to replace so try a new one. if still no spark then replace the coil.
SOURCE: I need wiring diagram for honda exw 280d generator welder
You will need to contact Honda directly for wiring issues.
SOURCE: honda e2000i generator no spark
if there is no spark in the plug as you are saying for that matter check the current coil and the inverter section for the loss of current if you have already changed the sparkplug if not do change
