20 Most Recent
Miller Trailblazer 302 Welder Generator 907217 907216 Questions & Answers
Miller trailblazer 302 it has 110 volts but no 220 volts
Both sets of the 120? If both of those are there (all 4 outlets), then the machine is producing 220v. So get a flashlight and look into the holes on the 220 receptacle, or check the wires on the backside of the receptacle. All that 220 is, is two 120 volts out of phase.
2/23/2015 2:41:30 AM •
Miller...
Answered
on Feb 23, 2015
I have no power at the plugs. tried to reset but nothing
Replace coil. Check power to coil first with a test light. If there's power, then coil is bad or the problem is under the distributor cap. Could be air gap has moved wider or the rotor tip is dirty. Clean it and try again. It's rare the air gap will move. Could be some rust on the rotor from condensation. clean it all. Try it. still no run, replace the coil.
10/15/2014 11:56:18 PM •
Miller...
Answered
on Oct 15, 2014
Can low oil cause welder not to perform
The oil is used as a cooling system, therefore if you ran a machinery without expect to overheat, dismantle your welder and check which parts have melted, repare or replace them and make sure there is enough oil at all time
6/8/2014 7:29:33 AM •
Miller...
Answered
on Jun 08, 2014
