SOURCE: Can't reprogram the remote controls.
The light indicator comes on but it never connects with the remote control & I have to reprogram the key pad when, I follow the directions on the unit.
SOURCE: Unlock radio code
the radio station buttons numbered 1 2 3 4 5 6. enter the 5 digit radio code there. if it locks up or goes to error you must remove the negative (-) battery cable to reset the radio and try again. it will let you try 3 times.
SOURCE: DL 2700 Alarm lock malfunction with constant alarm
I have had this happen on a 3500 and I had to replace the keypad assy. But, you may want to try to restore factory settings just to see if it resets. Disconnect the battery pack and hold down any number key for 10 seconds (this bleeds off any charge that may be in the capacitors). Reconnect the battery and within 3 seconds, press and hold the "A" key. After hearing 6 beeps, release the "A" key and wait for 5 seconds for the lock to re-lock (listen for 1 beep and red LED).
If successful, this will reset factory settings, which means the master code is now 1 2 3 4 5. If you need a programming manual, go to www.alarmlock.com At the top of the home page click on "support". Scroll to the bottom of the support page and click on Technical Library. Scroll down that page and find "trilogy DL programming manuals" and under that click on "download DL2700 enhanced instructions". I hope this is some help!
SOURCE: Trilogy dl 2700 serries digital lock program managers code
First you need to know if you have a standard 2700 or the new enhanced version, it makes a big difference. Press any 2 buttons then star, if you get no response it is a standard version, if it beeps several times it is the new version. If it is the standard version, disconnect the battery and press any button. Now you are at factory default. Reprogram the master code, remember the master code and the operating code must b e the same length. 12345 A 1 A new master code A new master code. The master code is the only code that needs to be entered twice during it's programming. To set a manager code press; master code A2A new manager code, to set a new user code; enter master code or manager code A11A new user code. The programming must be done during the lock's unlock window so write down the procedure you intend to use to make things go quicker, if you need more time you can change the unlock window, it is probably set at the factoy 5 seconds. Press master code A45A4, this will give you a 20 second window to program the lock, when you are finished change the lock back to 5 seconds, press; master code A45A1, keep the open window short to conserve batteries.
SOURCE: How do you erase an old code and input a new code?
Programming info at http://dl.owneriq.net/a/a8480104-048d-488f-8efb-03836644d506.pdf
More manuals etc located at http://homeappliance.manualsonline.com/manuals/mfg/schlage/be365.html
If this helps pls leave feedback
This
option restores the .ini files from the ROM.
Does not erase data
(photos, videos, documents) or applications from
a third party.
Key
Code *#7780# (click
this combination of keys on the
keyboard in the mobile)
2.-
Total Reset or Hard Reset
This
option restores the original operating system from the ROM.
Formats
the C: partition and deletes all data including the memory
card.
Key Code *#7370#
(click
this combination of keys on the keyboard
in the mobile)
Important:
To
proceed to reset,
the battery must be full and the
mobile device connected to the
charger. If during the course of reset,
the mobile stop receiving
electricity it can ruin the internal flash
memory of the mobile
device and stop function.
