20 Most Recent
Trilogy Alarm Lock T2 TRILOGY Digital Locks DL2700 Questions & Answers
We have a Trilogy lock that when you turn the
I've included a link to the installation instructions for the DL 2700 lock, which is a PDF file requiring Adobe Reader or similar program be installed to open the PDF:
http://napcosecurity.com/download/DL2700_WI835_INST.pdf
Scrolling down to page 8 of the instructions (Troubleshooting) indicates that if the lever will not fully retract, then the lock is either not full engaged with the latch or is misaligned, or that the lock is not centered on the door.
This link:
http://alarmlock.com/tech_library_instruction_manuals.asp
takes you to the tech support page, where you can find more documentation or contact their Customer Support directly.
How do i install the trilogy dl2700?
Go to this web page:http://www.alarmlock.com/tech_library_instruction_manuals.aspfor Alarm Lock, the manufacturer, and scroll down to the installation instructions for your lock.These instructions are in the form of PDF files. If you can't open them, you need to install Adobe Reader first. You can get the free download here:http://get.adobe.com/reader/Good luck, and please provide feedback if this helps!
How do I change the
Here is the website for Alarm Lock, the manufacturer :http://www.alarmlock.com/From here you will find technical documents and a link to customer service for further assistance. Good luck!
Lost code trying to reprogram T2 DL2700 with key
This is the website for Alarm Lock, the manufacturer:http://www.alarmlock.comFirst find out if you are dealing with a D2700 or the newer enhanced version. Press any 2 buttons and *,if you get a green LED and 6 beeps it is the new version. Good luck!
I have a simplex T2 DL2700 I put in the code the
Trilogy LocksThis is the website for Alarm Lock, the manufacturer:http://www.alarmlock.comFirst find out if you are dealing with a D2700 or the newer enhanced version. Press any 2 buttons and *,if you get a green LED and 6 beeps it is the new version.
I have a T2 that has the 12345 code as an entry
Will not lock
This is the website for Alarm Lock, the manufacturer:http://www.alarmlock.comI suggest you contact them directly for your problem.
Put new batteries in and
I will give you the link to the page with all the info that you need for installing or reprogramming your lock:
This is the website for Alarm Lock, the manufacturer's, tech literature page:
Notice
that links on that page are of the .pdf filetype. That means that you
need to have Adobe Reader or similar installed on your computer to view
them. So if you are unable to view a file, download (for free) and
install Adobe Reader first. You can get it here:
Also,
new version.
If you are unsuccessful in programming new codes
from the info provided above, I suggest contacting Alarm Lock for
technical assistance by phone: 1 800 ALA-LOCK.
Good luck--and please provide feedback if this helps!
I am having issues w/
Hi Val,
Notice that links on that page are of the .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view them. So if you are unable to view a file, download (for free) and install Adobe Reader first. You can get it here:
Also, find out if you are dealing with a D2700 or the newer enhanced version. Press any 2 buttons and *,if you get a green LED and 6 beeps it is the new version.
If you are unsuccessful in programming new codes from the info provided above, I suggest contacting Alarm Lock for technical assistance by phone: 1 800 ALA-LOCK.
I am trying to restore
For your problem you are best served by calling them at 1-800-252-5625. They are located in New York, so east coast business hours. I,m sure they can hook you up with a technician that can help you.
I have a trilogy dl2700
For Technical Service 1-800-645-9440
I recommend that you call during business hours and explain your problem. I'm sure they will be able to advise you on this. Be sure to have any relevant model/ serial numbers as you are able to provide. There is more than one version of the DL2700.
Trying to identify and trouble shoot digital lock
Here you will be able to find your model number and programming
information. Notice that the individual links on that page are of the
filetype PDF. If you are not able to view a given file, you will need to
download and install Adobe Reader; get it here free:
You will also be able to find the Contact link on that page for further assistance from their Customer Service department if needed.
