Whenever I turn the machine on at the wall the display lights up (no cycle has been selected) and it beeps constantly. Turning the dial to a cycle doesn't fix it, or make any difference to the screen or noise
SOURCE: hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
SOURCE: hot point wmlt80, dail clicking and turning, cycle wont start,
Yes, I work for GE what you need to do is to resent the appliance. Something should had happened with the computer of the washer. Just unplugged the machine for 40 seconds. You can unplugged or turn off the circuit breaker for 40 second and plugged back in. Select a normal cycle and let it run.
SOURCE: washer displaying "LD" and constantly beeps
Sometimes the LD on certain machines can be decieving, It's possible that the error is pointing to a lid lock issue. I'm a sears tech but have logged of my work computer for the night so I can't look it up right now. I just happened to stumble on this forum. In all appliances there is a tech sheet hid somewhere. This will give you more information. On this model, if you press and hold anykey for 3-4 seconds, let it up for 3-4 second and do that 3 times it will show more codes and go into a test cycle. Don't worry you cant screw anything up in the controller. If you or anybody needs help on appliances you can drop me a line. I have been a Sears tech for 15 years and have seen a lot of stuff and learning more all the time. scottowa at hot mail
SOURCE: Hoover Washer/Dryer WM120 : Dryer function - drum not turning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
treru
sounds like the clock or dial has gone if so a very expensive part to replace some times cheaper to buy new washer
