SOURCE: washing machine
the problem you are have there is if the machine is bolwing a fuse becauce the heater element is falty replace the heater and all shall be fine again noffie....
SOURCE: hi,i have a washing machine miele w 3000 tech
Mine is W3844. Miele's technician said the Wather Path Control Unit (part # 6271992) need to be changed.
Total Cost: (HKD)
450 for todays check cost
1100 for the part
250 for the labour to change the part.
SOURCE: bosch exxcel 1200 express washing
I had F63 on Bosch washing machine (Maxx 7).
I waited 5 days for a repairman and all he did was reset the washing machine processor, like this:
1. Turn the program knob to 6 o'clock
2. Hold the RPM button
3. While the RPM button is held, turn the program knob 1 click clockwise (to Rinse)
4. Release the RPM button.
This is similar to F21 which also happened to my machine.
Apparently both errors are related to power surge/power cut.
SOURCE: I have F63 flashing on Bosch exxcel 7 washing
Hi Error F 63 means Functional safety error. It appears when processor has broken SAFETY ERROR. To reset this error you'll have to switch ON/OFF the washer to reset the error. If the issue persists then check whether washing program is halted or aborted, if the washer doesn't advances to next cycle then you
