See images below
First you must use a graphing calculator.
Most graphing calculators graph functions, i.e. relations of the form y=f(x).
Some graphing calculators are able to graph equations (not necessarily functions). On one of these calculators your draw the vertical line x=-3, then you shade to the left of the point x=-3. That gives you the real line from infinity up to but not including x=-3.
Generally, people do not need calculators to find the solutions to inequalities in just one variable.
Testimonial: "My students are needing to graph systems of inequalities. One is x<-3 and the other is y>-5x-3. We are having trouble entering the 1st inequality into the graphing calc."
There is no problem graphing an inequality (in two variables) that involves a function (in the proper meaning of the term) but with an inequality such as x ) to reach the inequality graphing features.
Another simple way is to restrict the domain of the graph to x Greater than or Equal to -3. The half plane that is shaded by the 2nd inequality will be the solution space.
SOURCE: How would you enter the following equation to
To enter the inequation you split it into two inequalities
Graph is as follows
Use [2nd][CATALOG] to access the relaional operators less than or equal, greater than or equal, and the operator AND.
To access the inequality signs scroll upwards from abs( to reach the bottom of the catalog.
Note: You can use t as variable only in parametric graphs. Use x.
Hope it helps.
SOURCE: the calculator doesnt graph two equation on the
The Transfrm application for dynamic geometry is probably active in memory. You must purge it from RAM
SOURCE: graph y1 = 2x +1 if -1< x< 0
Graph 2X PLUS 1 for X in open interval ]-1,0[
It should be entered as follows
(2X plus 1) (X larger than negative 1) (X less than zero)
In [Y=] editor and on line Y1= type your right hand side between parentheses (2X Plus 1). I use the Plus instead of the usual sign because the parser of the web site removes the sign.
[( ]2 [X,T,theta,n] [Plus] 1 [)] [(] [X,T,theta,n] [2nd][MATH] [3: larger than] [(-)] 1 [)] [(] [X,T,Theta,n] [2nd][MATH][5: less than] 0 [)]
Here are some screen captures to help you
SOURCE: when i press the Y function of my calculator
1. Press up or down arrow to move the cursor to the line of the setting that you want to change.
2. Press left or right arrow to move the cursor to the setting you want.
3. Press enter.
