Not red flashing lights but steady slow green flash in standby. When I start up again I have no source control. I have to hard reset each time to get control for HDMI etc
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
SOURCE: Luxor 42 inch lcd tv stanby light flashing and tv
Good day!!!!
Kindly,count the blinks of your TV because some TV have error code by means of how many blinks..
thank you
SOURCE: The standby light on our Luxor Combi is flashing
Flashing of standby light are fault indication, and is called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the number of blinks carefully for at least 3 times switch ON / OFF. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Blinking codes details to many popular brand TVs are given in detail.
