Texas Instruments TI-84 Plus Calculator Logo
A
Anonymous Posted on May 28, 2014
How many ml is 5 mg? - Texas Instruments TI-84 Plus Calculator
calculator way
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 07, 2023
calculator way
Contributor
Level 1:
Answers
Questions
0
Helped
1308
Points
6
For water, which has a density of approximately 1 gram per milliliter (g/ml), you can use the following conversion:
5 mg of water is equal to 0.005 ml (milliliters).
So, 5 mg of water is approximately 0.005 ml.
more info visit - https://www.calculatorway.com/5-mg-to-ml/
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on May 29, 2014
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444338
Points
622693
Milliliter is a unit of volume, milligram is a unit of mass (or weight). There is no direct conversion between them.
5 mg of water occupies 5 ml. 5 mg of gold occupies about about a quarter of a ml.
  • Jill Lombardi Dec 15, 2014
    Can anyone please help me? I take a 1ml B-12 injection and I cannot get it prescribed anymore and need to take a sublingual pill which is labeled 5 mg. How many 5 mg pills equal 1 ml???? Thanks!
How many mg is in .4 ml?
For water, 1 Liter (volume) has a mass of 1Kg.
milli (m) is "1/1000 of".
Kilo (K) is "1000 times".
So:
Mass: Volume:
1Kg = 1Lt
1 000g = 1 000ml
1 000 000 mg = 1 000 ml
1 000 mg = 1 ml
400 mg = 0.4 ml
Depending on what liquid you are weighing, the density / mass can vary.
If inkjet, I guess it will be similar to H2O.
If it sinks in water, it is denser.
If it floats on top, it's less dense.
A 5 ml bottle holds how many 60 mg drops of oil?
there is no direct correlation between ml and mg as one is a volume measurement and one is a mass measurement what you will have to get is the mass (grams) weight of 5 Ml of the oil before it can be determined
In a 5 ml bottle how many drops would there be if a drop is 60 mg?
You are mixing millilitres (Volume) with (Milligrams) Weight. For that you have to assume that 1,000 milligram is equal with 1 millilitre, but that only works with distilled water, which is also 1 cubic centimetre.
1,000 milligrams Therefore, there must be 1,000 milligrams in a milliliter, making the formula for mg to ml conversion: mL = mg / 1000 .Dec 21, 2021
mg to mL Calculator
How many milliliters to milligrams?
Converting MG to ML will vary depending upon the density. It is not possible to know how many MG equal ML because milligrams are used to measure weight and milliliters are used to measure volume. You would need to know the density of the item that is being measured.
Milliliters to milligrams
Converting MG to ML will vary depending upon the density. It is not possible to know how many MG equal ML because milligrams are used to measure weight and milliliters are used to measure volume. You would need to know the density of the item that is being measured...
2answers
WHAT IS THE DIFFERENCE BETWEEN MG AND ML
A Milligram is MG and a Milliliter is a ML. (MG) is used in dry measure and (ML) is used in liquid measure
1000 micrograms (mcg) EQUALS 1 milligram (mg)
1000 milligrams (mg) EQUALS 1 gram (g)
1000 grams (g) EQUALS 1 kilogram (kg)
1 kilogram (kg) EQUALS 2.2046 pounds
1 ounce EQUALS 28.35 grams
1 pound EQUALS 0.4536 kilograms
1 pound EQUALS 16 ounces
16 ounces EQUALS 453.6 grams
1000 milliliters (mL) EQUALS 1 liter (L)
1 liter (L) EQUALS 1.0567 quarts liquid
1 quart liquid EQUALS 0.9463 liter
4 quarts EQUALS 1 gallon
2answers
Convert mg to ml
Milligram is a unit of mass (or weight), milliliter is a unit of volume. Any conversion between them depends on the density.
62.5 milligrams of water occupies 62.5 milliliters. 62.5 milligrams of gold occupies about 3.2 milliliters.
2helpful
How to convert mg to mL
mg is a unit of mass, ml is a unit of volume. There is no conversion between them. A mg of water occupies about a ml, a mg of lead takes up a lot less space.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
