I have a 42inch hitachi ultravision hd plasma. Ive been having to reset it to get a blue light but know its stuck in standby mode and know it wont turn on at all.
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
SOURCE: Powers up but picture doesn't appear.
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
SOURCE: Hitachi Ultravision won't turn on
it is the power board in the tv hase some bad capasators in it but can cost some money to fix if unsher how to do it on your own if you live in central new york i do have my own shop and im cheep but i can not warenty any thing but i can help 315-280-0508 storm electronics ask for corey
SOURCE: Hitachi Plasma P50S601 no picture sound OK
probably needs new scan drive board along with upper and lower buffer boards. it wont be cheap and its best to have a tv shop do it.
Hitachi 42HDS69 stuck on standby.
I have the same problem. For a while about once a week I would have to upnplug the TV from the wall to get it to turn on. The red standby light was on but the blue light didn't come on and the TV didn't either. Some times the RED light was off also but when I unplugged it fixed it. Now I have just the red standby light and even after unplugging the TV it will not turn on.
No.red.light.standby.moad
