20 Most Recent Hitachi Ultravision P50S601 50 in. Plasma HDTV Questions & Answers
Factory reset hitachi tv
To do a factory reset (System reset); you have to enter its service mode option. Like older model TVs, there is no switch marked "Reset"; to latest model sets. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
9/8/2019 8:43:01 PM • Hitachi... • Answered on Sep 08, 2019
0answers
0answers
0answers
My hitachi turns on and says no sync no signal
1. Make sure you're computer is properly connected to the monitor. 2. Some monitors have an input switch. Make sure yours is set correctly as it may have changed. The "signal" your monitor is looking for is sent from your computer.
4/30/2014 6:28:37 PM • Hitachi... • Answered on Apr 30, 2014
0answers
Wont turn on
Be the first to answer 4/14/2014 3:13:44 AM • Hitachi... • Posted on Apr 14, 2014Be the first to answer
Wont come on at all no blue light
If there is no blue light and no sound, then power is not making it into the unit. Is there a red light when it is plugged in? Many of these plasmas have a primary power switch located underneath or on the back. Make sure that is turned on. If you receive power, there should be an indicator light showing power is present. If it is just dead, as if unplugged, then either the main switch is off or failed, or the power supply may need service.
4/13/2014 8:46:51 PM • Hitachi... • Answered on Apr 13, 2014
2answers
My hitachi p50s601 turns on for 1 second and then
3 Blinks means one of the buffer boards is bad. The way to test it is to unhooking one SDR board at a time, and see if half of your screen comes on properly. If the SDR-D board is bad the bottom half of the screen won't come on when you remove the board. Send it out for repair (less expensive then buying a replacement board) or search for a refurbished board. If your non technical provide this info to a service tech and ask for an estimate. Cost will be moderate. Hope this helps you. Jon
4/13/2014 12:52:27 PM • Hitachi... • Answered on Apr 13, 2014
No picture but sound ok
There are many reasons for this fault. It is difficult to type in all details here by this window. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window
11/7/2013 1:33:15 PM • Hitachi... • Answered on Nov 07, 2013
TV went dead. No power lights at all
Check its fuse at the main power supply regulator board.
2/5/2013 3:28:16 PM • Hitachi... • Answered on Feb 05, 2013
How do you adjust color allignment
There is no adjustment for that like old CRT tv's convergence rings. The set needs repaired.
12/30/2012 8:18:37 PM • Hitachi... • Answered on Dec 30, 2012
Hitachi tv turns on then gets bad picture than turns off blue light blinking
The name of the part is probably "buffer board" and there are two in your TV - upper buffer and lower buffer, also called SDR-U and SDR-L boards.Those are the two most common sources of problems in P50S601 along with the Y sustain board (SD board in hitachi and Panasonic terminology), which sometimes gets damaged by the failed buffer board.In the buffer boards market there are all kinds of offerrings. There are old buffers for around $130 for the pair and there are new buffers in the range $160-$200 for the pair.In my opinion if the difference is barely $30-$40 one is better off going for the brand new ones.Here's a link to our title for them, you can sure find others if you start from it:http://www.coppelltvrepair.com/p/182/hitachi-nd60200-0048-and-nd60200-0049-replacement-set-of-buffer-boardsHope this helps!www.coppelltvrepair.com
12/15/2012 4:29:25 AM • Hitachi... • Answered on Dec 15, 2012
Channels will not change with remote or at the TV controls
Have a close look at the owner manual or Google the model for one as many sets have a LOCKOUT that locks both the remote and front/side buttons on the set out.
11/4/2012 3:49:52 PM • Hitachi... • Answered on Nov 04, 2012
Tv wont power up
check the power supply look for bulging electrolytic capacitors then replace it with new one.
8/30/2012 2:58:59 AM • Hitachi... • Answered on Aug 30, 2012
Have a P50S601 Hitachi Plasma TV - used in church only for DVDs - it clicked off, would not come back on. Pushed main power button off - unplugged. Left off till the next Sunday. Turned on Sunday a
Servicing by opening the back cover should be performed only by a qualified service technician.
8/16/2012 5:48:35 AM • Hitachi... • Answered on Aug 16, 2012
2answers
Need a schematic for model
This web page may help it has links telling you what to test. http://www.hometheatershack.com/forums/hitachi/30302-p50s601-blue-power-light-flashing-3-times.html like if your power light is flashing 3 times then it most likely is two caps in the power supply and one of the sdr boards.
8/6/2012 7:07:27 PM • Hitachi... • Answered on Aug 06, 2012
Hitachi Ultravision P50S601 50 in. Plasma HDTV Logo
85 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
hitachi turns says no sync no signal
  • Televison & Video
