I am using Dell Inspiron 1525 and have already attached an external mouse but the cursor still jumps to wherever my mouse is when typing. (it is still jumping as I type this)This is getting very inefficient and frustrating. HELP! :(
This is because you must deactivate your touchpad. you can do this by holding the Fn key and pressing the F* key that shows a picture of a touchpad in the same color as the Fn.
or you can go to control panel and turn it off in the mouse settings. but just attaching a mouse will allow the touchpad to stay active and therefore still be sensitive enough for your hand to "tap" th cursor.;
Good luck and pls rank this response! :D
then this will be your final solution. install the drivers here; http://support.dell.com/support/download...
this will install an icon on your toolbar to adjust the touchpad settings in which case you can disable touchpad click response.
badbaldass,
could you pls rank my post as "fixya" to boost my ranking to guru status?
thank you very much
and your welcome for the advice
you have inadvertantly rated your own post or comment and therefore locked all other ratings. if you wish to rate my post as fixya, simply open a new post as Dell Cursor coldsilver20 and i will repost my answer imediatley for you to rate
thanks a million
Thanks Coldsilver20
I really want to deactivate my Dell mousepad but it seems there's no such function/option to my laptop. :( The problem still persists.
Okays.. it seems to be okay so far! I hope it last! LOL thank you sooo much! you were AWEEEESOME! thank you thank you!
heys sure I would have given you four blue squares but its not showing on the site! I've clicked on the squares but nothing's changing.. any idea how to? im new around here. :(
