20 Most Recent Dell Inspiron 1525 Notebook Questions & Answers
3answers
I have a dell inspiron 1525 and it wont charge
If possible could you check output voltage of the charger with a multimeter? If you can get output voltage, then might be something wrong with laptop battery charging circuit. Contact Laptop Repairing Engineer.
Regards;
Hassan
11/29/2022 8:43:54 AM • Dell Inspiron... • Answered on Nov 29, 2022
I cant find my touchpad icon
Hello,You can do a system restore in your computer to revert it back to the known good condition.go to start or pearl > Accessories > System tools > system restore. Select the date when the synaptics driver was still in your computer.I hope this helps.
11/29/2022 7:54:13 AM • Dell Inspiron... • Answered on Nov 29, 2022
Disable inspiron 1525 keyboard
Step 1: Dell sells technology such as computers, computer peripherals and consumer electronics to both consumers and businesses. Dell sells both wired and wireless keyboards and mice that are compatible with Dell and other computer systems. Dell wireless keyboards may encounter hardware, software or other problems under certain conditions. Power Dell wireless keyboards transmit data to the Dell USB receiver, which in turn passes the data to the computer's operating system. The keyboard gets power from two AA batteries. As the batteries lose charge, the keyboard's transmissions can become intermittent. Replacing the old batteries with fresh ones will ensure consistent communication and resolve the power issue. b> Interference Dell wireless keyboards operate best and are least susceptible to interference when the user places them at the recommended distance from the USB receiver. The distance, specified in the keyboard's accompanying software or installation guide, varies by keyboard. Even if the user places the keyboard at the proper distance from the USB hub, metal objects between the keyboard and hub can create interference; moving objects that create the interference resolves the issue. b> Connection The Dell USB receiver that passes data from the keyboard to the computer requires proper and secure installation in a working USB port. If the receiver connects to the USB port improperly, or if the USB port to which the receiver is connected is faulty, the keyboard will not operate as expected. The user can reseat the receiver in the USB port, or connect to the receiver to a different, functioning USB port to resolve connection problems. b> Synchronization Dell wireless keyboards can broadcast at more than one frequency, just as their associated USB receivers do. If the two devices broadcast at different frequencies, they will not pass information to each other. The user can resolve this situation using the buttons labeled "Connect" on the top of the receiver and the bottom of the mouse. Pressing the buttons simultaneously triggers the synchronization process. b> System Dell wireless keyboards are compatible with most Dell systems. However, a keyboard may be incompatible with a given computer for reasons related to the computer rather than to the keyboard. To determine if this is the case, a user can connect the keyboard to a different computer. If the keyboard functions as expected with the second computer, the problem may reside in the first computer rather than in the keyboard. Dell wireless keyboard problems http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=715E6659A4141AFAE040AE0AB7E10D59&doclang=en&cs= - Issue0_1
11/29/2022 7:51:34 AM • Dell Inspiron... • Answered on Nov 29, 2022
Screen flickering
Try with new battery pack. It may be faulty RAM too.
11/29/2022 7:39:09 AM • Dell Inspiron... • Answered on Nov 29, 2022
How can I free up space on os(c:) disk
Usually the most memory from your hard drive is reduced from some big files like movies or games,video editing programs etc.Download Treesize! A freeware that can tell you exactly what is using your memory space.http://www.jam-software.com/freeware/
11/29/2022 7:37:25 AM • Dell Inspiron... • Answered on Nov 29, 2022
4answers
Keyboard wont work
Take the computer to a qualified technician for trouble-shooting.
It could either be a loose cable between the keyboard and the motherboard, or it could be a dead keyboard.
Either way, it is not a "user-serviceable" part;
so, pay the technician to get it repaired safely & correctly.
11/21/2022 9:00:38 AM • Dell Inspiron... • Answered on Nov 21, 2022
24answers
Dell inspiron 1525 will not charge the battery
1525 owners (possibly other models) DO NOT replace the mobo before reading this! Just read step 3 and 3a.
The Dell 1525, 600 series, and probably all other models using PA10 or PA12 power supplies have a power jack that uses the center pin to detect the presence of a genuine Dell power adapter. There have been considerable writings on the problems with this 3rd pin on the internet.
The symptom is that you can run the laptop when plugged in but the battery won't charge and you get a warning message that you are not using the proper power supply or it can not be identified.
The best place to see power supply status in the BIOS under battery status.
You MUST use a genuine Dell adapter, period. None of the non OEM supplies have the center pin enabled (proprietary chip).
CAUSES:
1. The power adapter sensing line can be damaged by static electricity but I find this to be rare.
2. The center pin in the power supply is loose or the wires are breaking (test by wiggling the power cord at the strain relief while holding the plug steady in the laptop - replace the power supply for $<20 on eBay.
3. The center pin connector on the laptop jack is loose - symptom is that it works sometimes and not others. Requires a full breakdown and replacement of the jack. Can be done yourself if you are very handy AND WILLING to FOLLOW DIRECTIONS which are excellent on the Dell web site. Does require soldering on most laptops.
3a. At least on the 1525 there is a sub board for the power and USB which you can get for $80 on eBay and just plugs in - still requires pretty much total breakdown. The board itself is usually the problem so replacing the connector won't help - it is in the multilayer trace from the power jack to the mobo connector. There is a bypass wiring method that requires super close tolerance soldering - I will post that if asked.
4. On some older models (P4 1 core) you can go into the BIOS and turn off Intel speed step to get the laptop running - it will run slower but you probably won't even notice the diff.
This whole mess is the result of Dell trying to protect the mobo and battery (life and fire prevention) but packing too much wiring into a too small package. They should have used a larger, 3 prong type power jack knowing how much strain is put on the power cord.
11/21/2022 8:58:06 AM • Dell Inspiron... • Answered on Nov 21, 2022
2answers
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
11/21/2022 8:54:12 AM • Dell Inspiron... • Answered on Nov 21, 2022
Dell inspiron 1525 shutdown problems
Press and hold the power button. It sill shut down completely. If this fails, just remove the battery.
11/21/2022 8:51:59 AM • Dell Inspiron... • Answered on Nov 21, 2022
4answers
Fix error code 579 windows update
try this solution from this link
http://social.answers.microsoft.com/Forums/en-US/vistawu/thread/f9a0bc73-7172-4429-84ce-ca249d6fbfd5
11/21/2022 8:47:55 AM • Dell Inspiron... • Answered on Nov 21, 2022
2answers
Post Boot Freeze
It freezes because one of the programs set to start at boot crashes. To identify which immediately after booting open Task Manager and look at the processes - one should reach 99% CPU use. Once you have found it stop it from launching at boot or just uninstall it.
11/21/2022 5:58:42 AM • Dell Inspiron... • Answered on Nov 21, 2022
2answers
We have a Dell Inspiron
If you have some region-locked DVDs and you can't play on your DVD player, you can remove the region code by just get a dvd copy disc without region codese. You can try Leawo Blu-ray Copy which enables you to remove region code from Blu-ray and DVD.
11/7/2019 8:49:07 AM • Dell Inspiron... • Answered on Nov 07, 2019
Error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
7/25/2019 11:47:16 AM • Dell Inspiron... • Answered on Jul 25, 2019
2answers
I have a dell inspiron 1525 that i need to reset
I can help you but I need tag or serial number from the screen.
11/9/2017 10:36:42 PM • Dell Inspiron... • Answered on Nov 09, 2017
Start up services.
Vista is no longer supported. Install a Linux distribution
10/20/2017 11:36:55 AM • Dell Inspiron... • Answered on Oct 20, 2017
2answers
MY DELL INSPIRON 1525 SUDDENLY STARTED ASKING FOR
There are different kind of passwords, System password, System setup (BIOS) password, Windows password etc. Do you see the windows logo after which it is asking for the password or do you get this screen before that?
Please click on the link below and understand different types of passwords and how to get it back, if you need more help please reply to this post.
http://www.fixya.com/support/r7153937-lost_password_cannot_login_computer
6/21/2017 7:46:46 AM • Dell Inspiron... • Answered on Jun 21, 2017
Dell Inspiron 1525 laptop, no
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
5/19/2017 9:39:16 AM • Dell Inspiron... • Answered on May 19, 2017
Noisy cooling fan, how do I replace it?
If under warranty, contact Dell Technical Support.
If not under warranty, check Manul to replace
http://support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
2/1/2017 12:12:10 PM • Dell Inspiron... • Answered on Feb 01, 2017
What is the key with the windows symbol on it
Hi Marci, there used to be a Microsoft Fixit download that you could download & run to resolve this issue, but MS retired it.. Follow these instructions and this will also resolve this issue: To enable the Windows key, follow these steps:
  1. Click Start, click Run, type regedt32, and then click OK.
  2. On the Windows menu, click HKEY_LOCAL_ MACHINE on Local Machine.
  3. Double-click the System\CurrentControlSet\Control folder, and then click the Keyboard Layout folder.
  4. Right-click the Scancode Map registry entry, and then click Delete. Click Yes.
  5. Close Registry Editor and restart the computer.
**SEE SCREEN SHOTS*** Please reply with results and mark Helpful Thank You Doug key-windows-symbol-phpl4x1vytofgz1f231vdhlm-1-0.jpg key-windows-symbol-phpl4x1vytofgz1f231vdhlm-1-2.jpg key-windows-symbol-phpl4x1vytofgz1f231vdhlm-1-5.jpg REBOOT
10/9/2016 8:56:41 PM • Dell Inspiron... • Answered on Oct 09, 2016
Dell Inspiron 1525 Notebook Logo
1,880 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
dell inspiron
  • Computers & Internet
