I have a dvd stuck in the tv/dvd combo. i think it may be in upside down? there is no obvious eject buttons.
SOURCE: DVD is stuck
i dont know yours but most dvd players have a small hole in front thst you can insert a paperclip in and release the dvd door
SOURCE: dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
SOURCE: dvd stuck in dvd
Lay the TV, face down on a folded towel. Remove all the screws. Note: there is one perimeter screw with machine threads; all the others are the same.
Remove the four black screws from this area:
Then you can pop the back loose and slide it towards the end where the black screws were. It just lifts off and there are no wires attached.
Now you can see the DVD player. I used the end of a plastic pen to shove against the edge of the DVD that you can see through this slot.
Press on the DVD's edge until you see it come out the entry slot.
You can see the DVD slide out the entry slot as you are pushing.
When done, slide the back into place and replace the screws.
SOURCE: DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
SOURCE: Stuck DVD
I removed the DVD but it continues to show display on the screen "door open" on the DVD and will not go to the TV menu. The remote will only turn the tv on and off. HELP!
