The screen is turned into a full dark spot. I changed the batteries with fresh ones, but it doesn't fix it. I cleared the RAM but nothing happened. What can I try? I only miss to change the circular flat 3 v lithium battery, but I don't think it will help. Some one can help me?
SOURCE: texas instruments ti-83 plus. only have black line on screen
Reset the calculators memory [2nd][MEM][7:Reset][1:All Ram][2:Reset]
If that does not work
You should reinstall the system which you find here
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=1&paneId=2
Use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there.
Install TI connect on your computer and run it to open the main Window. Then connect
you calculator to a USB port and, in the TIConnect main window Click
the TIDeviceInfo icon. Software will try to retrieve the info. If it
does your calculator is fine.
If it tells you Device Not found ,
Click communication settings in same pop up window where it said Not
found, and Select Device, Select Cable, Select Port and Click OK..
If
you are lucky and it works, you can reinstall the OS, which can be
downloaded from education.ti.com. You drag and drop the OS on the
TIconnect main window. Calculator must of couse be connected to computer.
If
you have problem with TIconnect, use the calc-to-calc cable to transfer
the OS of a working calculator. Yous should be on Receive mode
[2nd][Link] --->>Receive. (When both calculators are ready hit
enter.) The other calculator, you guessed exactly right, must be on
Send [2nd][Link][SEND][G:SendOS]. (When both calculators hit [ENTER])
If
all that does not work, then it may be time to head for a place of
worship to pray for its resurection, or look for a repair shop.
Hope it helps
SOURCE: Texas Instruments Ti-83 Plus Help
possibly water damage... there might be an indicater of this such as one on a cell phone. behind the battery possibly, a small sticker that changes color when dampened.
as for solutions... warrenty? lol
SOURCE: TI-83 Plus Silver Edition problem
Use a paperclip (tiny hole on back of caculator) and reset.
JC
SOURCE: ti-83 plus silver edition. calc won't turn on.
Well, if screen shows the RAM CLEARED message, that means your calculator is working. Just press the [CLEAR] key, message will be erased and you are ready to crunch numbers.
Hope it helps.
SOURCE: New batteries, turned it on and screen is completely black.
First, try adjusting the contrast. Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow for a few seconds and see whether the screen lightens.
If that doesn't do it, remove all four AAA batteries. Press and hold the ON key for at least ten seconds. Replace the batteries.
If that doesn't do it, add a comment here and we'll go from there.
