There HAVE to be a thermostat to cycle unit .Is there a sight glass on the liquid line .If there is normally you charge it up until you see no more bubbles in the sight glass.
There is never a constant pressure reading because pressure depend on outside temperature .
Thermostat for freezer will not look like regular thermostat.
I will be in the evaporator section
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
SOURCE: GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
SOURCE: Refrigerator section not cold enough
may have damaged the valves on the unit when it froze up and check the amperaeg of the compressor and so if its running close to the full load amps.
SOURCE: I have a magic chef
OK as long as you used a hair drier, and not a screw driver to defrost this machine, you should be fine, it shoudl take no more then 24-36 hours to regain the correct temp, this being said, not real comfortable with the over the internet diag of a unit that potentially "keeps people alive"
SOURCE: Refrigerator section on side by side losing cooling
Here is the Amana website with the manuals which should show you where the defrost timer etc. is located. Witht your model number and manual it will be a lot easer
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=AMA
And yes the defrost timer thermostat and heater are the most likely problem.
Do not let this keep running and running or you may lose your compressor too which means a lot more expense than now.
