I have a 9 year old Hotpoint free standing gas range with self-clean oven. When I try to ignite any of the top 4 burners, it will take a long time to have flames. I see spark and no flame. But as soon as I hear gas flowing, the burner lights up right away. All of the rest burners will then light up as well. If I turn all of the burners off and wait about 30 minutes. I have to do the whole process again - let it click for a long time and eventually it will light up. But if I turn all burners off and restart them right away, I have no problem having any of the burners to ignite. Oven seems to work fine.
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
SOURCE: Dacor ERD30 Epicure dual fuel takes two minutes for gas to flow
Have a look at manual below
http://www.dacor.com/Dacor.Website/WorkArea/showcontent.aspx?id=1297
Or select from here
http://www.retrevo.com/s/Dacor+ERD30?rt=mi&p=http%3A%2F%2Fwww.dacor.com%2FCustomer-Care%2FManuals-And-Specs.aspx%3FTaxonomyId%3D509
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
If you hear clicking or sparking, go to Step 2.
If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
Check to see if the burner works, If not, then go to Step 3.
Check to see if the burner works, If not, then go to Step 4.
SOURCE: xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
The repair person came in today and replaced the regulator valve. He claimed that it worked. But when I tried it, it didn't light up right away. Still it's a big improvement - time to light up from up to 2 mins down to about 15 seconds. I was a little disappointed but figure may be it's normal that it doesn't light up right away. I hope there isn't any more problems because I have already spent $180 for this repair. I will try again to see how it goes tomorrow.
