20 Most Recent GE Profile Spectra JGBP90 Gas Kitchen Range Questions & Answers
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
1/13/2023 8:33:18 PM • GE Profile... • Answered on Jan 13, 2023
GE Spectra XL 44 Self Cleaning
Ray, sometimes the burners get gunked up. Remove the cap and burner and see if the small orifice that is located by the spark electrode is clogged. Clean it out with a paper clip. Make sure the burner cap has good contact with the burner. Catriver..post back.
12/3/2022 5:06:35 PM • GE Profile... • Answered on Dec 03, 2022
GE XL44 Range - Buzzing sound when plugged into electrical outlet
Had this happen, was advised that it is most likely the clock board, and that there are NO internal parts available for the XL-44. Turned off the power at the breaker box, pulled the two upper back panels off (the bottom one must be removed first, as the top one has a difficult-to-access sheet metal screw on the bottom inside at either end), then just pulled the common neutral lead (white wire that daisy-chains along the various electrical bits) from the E2 terminal on the bottom left side of the clock board. Applied some heat shrink tubing to the now-disconnected neutral lead to keep it from shorting, and buttoned up everything. The clock is dead, but everything else works just fine and there's no annoying buzzing sound any more.
6/8/2021 9:52:40 PM • GE Profile... • Answered on Jun 08, 2021
2answers
GE JGBP85WEB5WW - F7 / E9 Error codes
Well first of all you determine if problem is with the Key Panel or Control by-
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
This error code means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC).
Post comments for more help or information........
Good Luck!!
12/22/2018 7:48:23 PM • GE Profile... • Answered on Dec 22, 2018
4answers
Probe and Bake blink alternately.
I had the same problem. I resolved it yesterday. Detailed instructions can be found if you access my inquiry under the user name bhmlton. If you can't find them, then let me know and I'll get them to you another way.
7/26/2018 4:08:21 PM • GE Profile... • Answered on Jul 26, 2018
0answers
Oven manual
Be the first to answer 1/3/2018 12:09:03 AM • GE Profile... • Posted on Jan 03, 2018Be the first to answer
Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
12/26/2017 8:05:55 PM • GE Profile... • Answered on Dec 26, 2017
0answers
0answers
0answers
0answers
1,583 questions posted
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
GE Kitchen Ranges
  • GE Kitchen Ranges
Most Popular Question
ge xl44 gas oven
  • Kitchen Ranges
