Posted on Jan 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rref for 4X4 matrix does not answer correctly
Whenever I plug in a 4X4 matrix then try to find rref form this is my answer no matter the numbers 1 0 0 .3333333... 0 1 0 .3333333.... 0 0 1 .3333333.... 0 0 0 0 0......
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Jan 21, 2012
k24674
Level 3:
Answers
8093
Questions
0
Helped
4675751
Points
21596
To make sure that the calculator is misbehaving, I suggest that you create a simple 4X4 matrix, that is not singular, and calculate it reduced row echelon form by hand, then use the calculator to perform the reduction. You can also generate a random 4x4 matrix and calculate the rref forms by hand and with the calculator. If the calculator is defective, try to upgrade the OS. If it is still defective, well, the deck is stacked aaginst you. It may then be time to get another one or to send it for repairs.
Calculator error
What's the determinant of the numbers in matrix A? A singular matrix is a matrix whose determinant is zero.
Scrolling sideways
Usually the right arrow allows you to move cursor to the right.
5helpful
How to find rank of matrix using casio991 es??
The FX-991ES offers simple matrix operations like basic arithmetic, plus the slightly more complex operations determinant and inversion. Furthermore, it is limited to matrices with a maximum size of three rows and three columns.
The rank of a matrix is defined as the number of linearly independent row or column vectors. You can perform a simple partial test for square matrices by calculating the determinant of the matrix:
  1. Enter the matrix into matrix variable MatA.
  2. Press [SHIFT] [4] [7] [SHIFT] [4] [3] [)] [=]
The display now should show det(MatA) and the determinant of the matrix in the result. If the determinant is not 0, the rank of the matrix equals the dimension of the matrix, otherwise the rank is less than the dimension.
Unfortunately, this is all support the calculator offers. For small matrices (i.e. 4x4 or smaller), you should familiarize yourself with the Gau? Elimination Method algorithm for solving linear equation systems. It is a two-step procedure where a matrix first is converted to its row echelon form, and second to row canonical form to solve the LES.
You need to follow the algorithm only through the first part, the number of non-zero rows after this step equals the rank of the matrix. With a little exercise you will be able to do it faster on paper than trying to do it with your calculator only.
For larger matrices I suggest to use a PC with more powerful math software (Maple, Mathematica, ...) or, if you know some basic computer programming, just write the necessary program yourself, which is also a very good exercise both in programming and understanding the algorithm.
How do i convert a decimal answer to fraction format on a TI 89 titanium.... prefferably with matrixes
It is just a matter of being in EXACT mode. To set your calculator in EXACT mode here's the key sequence. Press [MODE] [F3] [Up Arrow] [Up Arrow] [Right Arrow] [2] [ENTER]. Now when your in the Matrix Editor you can input your numbers in decimal form and, they will be automatically be converted to a fractional format. Pictured below is a matrix that was entered using decimal numbers and, was converted into factional form. Notice at the bottom of the screen the calculator is in EXACT mode.
Here's the same matrix in the HOME screen.
Next is the same matrix converted back to decimal numbers. Notice at the bottom of the screen the calculator is in APPROX mode.
And of course when I turn the calculator back to EXACT mode and, Re-ENTER the decimal formatted matrix in the HOME screen the fractional formatted matrix reappears.
You can use the propFrac( command but, having in the EXACT mode setting works better.
Matrix
Here is copy of the answer I posted to a question on how to use Matrices. Read it carefully. It helped a few people, and there is no reason why it should not help you too. If after a bona fide effort to understand it you still have a problem, post a comment here. What I am saying, is do not just shoot the answer, try it first.
First you must set Matrix calculation
[MODE][6:Matrix].
  1. Then By entering one of the numbers [1:MatA] or [2:MatB] or [3:MatC] you get to choose the dimensions of the matrix (mxn)
  2. Once finished entering the matrix you clear the screen.
The operations on a single matrix are available by pressing[Shift][Matrix]. They are
  • [1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
  • [2:Data] enter values in a matrix
  • [3:MatA] access Matrix A
  • [4:Matb] access Matrix B
  • [5:MatC] access matrix C
  • [6:MatAns] access the Answer Matrix (the last matrix calculated)
  • [7:det] Calculate the determinant of a matrix already defined
  • [8:Trn] The transpose of a matrix already defined
Operations involving 2 matrices
  1. To add matrices: MatA+MatB
  2. To subtract: MatA-Matb
  3. To multiply: MatAxMatB
  4. To raise a matrix to a power 2 [x2], cube [x3]
  5. To obtain inverse of MatA already defined MatA[x-1] where [x-1] is the x to the power -1 key
Dimensions of matrices involved in operations must match (see you textbook for the rules). Read the appendix to your user manual, there are several examples.
3helpful
When I divide the answer is in fraction form not decimal form how do i get it back
There are two options.
1) Whenever you want the answer in decimal form, place a decimal after at least one of the numbers.
For example: instead of using (1/2) use (1/2.)
2) Press the "Mode" button. Scroll down the list that appears until you find "Exact/Approx". If you set it to "Approximate", then it will always give the answer in decimal form. If you set it to "Exact", it will give the answer in fraction form.
3helpful
2answers
Steps in solving matrix on my ti 89 calculator.
I assume you are speaking of solving a system of equations with a number of unknowns. If not, please correct me. Here's an example in practice:
If you have a system of 3 equations with 3 unknowns, you would set up your matrix so that the coefficients of each variable for a particular equation are on one row. So, given equations x + y + z = 0, 2x + 3y - 4z = 1, x + -z = -1 you would type the following into your calculator: [[1,1,1,0][2,3,-4,1][1,0,-1,-1]] and press enter to make sure you typed it correctly. notice that in the third row there is a zero, since we have zero time y for the third equation. Then row-reduce the matrix (2nd > 5 > 4 > 4 or in the CATALOG as rref). You should get out the matrix [[1,0,0,-1][0,1,0,1][0,0,1,0]]. This says that x=-1 y = 1 z=0 since my first column contained the coefficients for the x variable, the second for the y variable, and the third for the z variable. The last column contains the solution, the part on the other side of the equals sign.
Hope this helps! For more reading (from someone else; I just made this one up), check out the Wikipedia articles on Gaussian elimination and Systems of linear equations
2answers
I need to know how to get to reduced row echelon form
i tried to graph a simple function but it wont show the lines it will only show the graph
5helpful
Solving matrix
Go to your matrix button and enter a "3x4" matrix.
Then enter it as follows:
-3 4 5 7
4 3 2 9
-5 5 3 -10
Then exit out and go to "2nd->matrix->math->rref(". Then press enter.
Your screen should look like this:
rref(
Then go to matrix and select your 3x4 matrix, press enter and close it with a parathesis. Your screen should look like this:
rref([A])
Press enter and the screen should say this:
1 0 0 2
0 1 0 -3
0 0 1 5
So,
x=3
y=-3
z=5
Hope this cleared up the confusion!
SJ_Sharks
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
