20 Most Recent
ESQ 07301132 Aerodyne watch Questions & Answers
Setting time day date in ESQ Aerodyne
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
ESQ 07301132 ...
Answered
on Sep 13, 2017
I just bought this watch
ESQ 07301132 ...
Answered
on Jan 23, 2013
How do I set the
step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync mode.
ESQ 07301132 ...
Answered
on Jan 04, 2012
Watch doesn't work
It would be difficult to state with certainty, because it wouldn't likely be possible to determine how long the watch was in storage before you received it.
Most watches will need batteries between 2-5 years after their manufacture.
Higher-priced watches could easily be that long on the shelf before sale, but I would contact the seller with your complaint.
The seller should at least be conscientious enough to ensure the watch is running prior to shipment.
ESQ 07301132 ...
Answered
on Nov 20, 2009
