20 Most Recent
Whirlpool GERC4110PS Kitchen Range Questions & Answers
Kitchen Aid KESA907 Error F2E0
Turn off the breaker and wait for 5 minutes. the follow these steps:
--> After turn the breaker back on, go to the range and press
"OFF", "OFF", "START", then click on the "clock set", there is a
message on the display saying that do you want to delete the error, at
this time press on the "START" again. And wait for a while until the
everything on the screen disappear except the clock time. Hope this
will fix yours. It fixed mine.
2/26/2018 9:12:47 PM •
Whirlpool...
Answered
on Feb 26, 2018
Two left burners no working on GERC4110PS
Replace the fuse that relates to theses burners. If nor sure, replace all the fuses. ..noting first where each was taken from. The 30 amps are for the oven; 20 for the elements. 15 for the light.
10/21/2013 2:48:53 AM •
Whirlpool...
Answered
on Oct 21, 2013
Inside of oven seperated.
Yes it is now extremely dangerous to use this oven. It seems that the extreme heat has warped the panels. This is not usually repairable. I would suggest that this oven be discarded and pictures sent to the manufacture. They may offer you some sort of help in the purchase of a new range. Hope this helps. Good luck.
11/18/2009 3:48:54 PM •
Whirlpool...
Answered
on Nov 18, 2009
Whirlpool gas range diagnostic code E6 46 (cannot find this error code combination anywhere)
E6 46 is a diagnostic code for a Whirlpool gas range. This code indicates that there is a problem with the oven temperature sensor. The sensor measures the temperature inside the oven and sends this information to the control board. If the control board detects a problem with the sensor, it will display the E6 46 error code.
To troubleshoot the problem, you'll want to do the following:
- Check the wiring: Make sure that all of the wires connected to the oven temperature sensor are secure and not damaged.
- Check the sensor: The oven temperature sensor is located in the back of the oven, near the top. Make sure that the sensor is properly seated in its socket and that it is not damaged.
- Check the control board: If the wiring and sensor appear to be in good condition, the control board may be the cause of the problem. You'll want to check the control board for any visible damage or loose connections.
If you are unable to find the problem, I recommend having a qualified repair technician diagnose and fix the issue for you. Electrical issues can be complex and it's important to address them promptly to prevent further damage.
1/8/2023 1:32:12 AM •
Whirlpool...
Answered
on Jan 08, 2023
What is F9 code for whirlpool stove
The F9 error code on a Whirlpool stove typically indicates a problem with the oven temperature sensor. The oven temperature sensor is a device that measures the temperature inside the oven and sends this information to the control board. If the sensor is not functioning properly, it can cause the control board to display the F9 error code.
To troubleshoot the problem, you can try the following steps:
Check the oven temperature sensor: Make sure the sensor is securely connected to the control board and not damaged. You can also check the resistance of the sensor using a multimeter to see if it is within the specified range.
Check the wiring: Make sure all the wiring for the oven temperature sensor is securely connected and not damaged. Check for any frayed or damaged wires, and repair or replace them as needed.
Check the control board: If the oven temperature sensor and wiring are in good condition, the problem may be with the control board. You can try resetting the control board by unplugging the stove and waiting a few minutes before plugging it back in.
If these steps do not resolve the issue, you may need to take the stove to a professional appliance repair shop for further evaluation and repair. They will be able to diagnose the problem and recommend the necessary repairs.
12/24/2022 4:37:31 PM •
Whirlpool...
Answered
on Dec 24, 2022
