20 Most Recent Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Questions & Answers
Kenmore Elite 79571033010 bottom-mount refrigerator. How to remove multi air flow panel in 795.71033.010
Question edited for clarity, full make model (what is is)'. Question moved to category. Help here plus 795 Service manual https://www.google.com/search?q=795.71033.010+remove+multi+air+flow+panel ..
12/25/2023 10:44:52 PM • Kenmore Elite... • Answered on Dec 25, 2023
New fridge coming today...
Good day,
If it's being delivered by an appliance company, they know that the machine has to be transported upright. So no. You should be able to plug it in as soon as it's set up.
IF the machine is transported on it's side, then yes, a minimum of 24 hours is necessary to get the oil back into the compressor.
6/24/2023 10:33:44 PM • Kenmore Elite... • Answered on Jun 24, 2023
2answers
Interior Lights "ON" With Doors Closed
Jane0901. Go to the following web site. Look at the solution section concerning Sears Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Service flash "sf46-515". I am "DaleCos" and have the same problem. I have reported the probem to Consumer Reports and the Consumer Product Safety Commission. More people need to contact these two organizations. Good luck.
http://www.fixya.com/support/t968825-interior_lights_doors_closed
1/7/2023 2:02:25 AM • Kenmore Elite... • Answered on Jan 07, 2023
2answers
My freezer builds up an ice layer on the bottom of the freezer under the drawer any idea why?
Your defrost drain tube is clogged somewhere along the way.
12/16/2022 12:16:04 AM • Kenmore Elite... • Answered on Dec 16, 2022
Kenmore Elite 79571053010 bottom-mount refrigerator. where can I find electrical print for 79571053010?
Question edited. This appears to be a refrigerator. 'Make Model (what it is)' in all questions please. Question moved from 'Office Equipment and Supplies'. 'electrical print'? You mean like a wiring diagram? Normally only available to Service engineers, but some help in the link. Click on the images tab. You can narrow results by putting the "model_number" in "quotes".
4/26/2022 8:27:52 PM • Kenmore Elite... • Answered on Apr 26, 2022
2answers
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
2/24/2022 6:47:32 PM • Kenmore Elite... • Answered on Feb 24, 2022
4answers
My Kenmore Elite freezer door came off one of its
I just spent the better part of an hour on this. There is a white flange with two phillips screws. If you take this off it is easier to see the mechanism, but you may be able to get it back on without removing the flange. I removed the flange. The mechanism attached to the door has a hook facing up and a smaller hook facing down. There is a hinged metal bar below this. The bar has a hinged piece with a loop on it. Pull the loop up. Now push down on the piece with the hooks ( it has a spring) and hook the smaller hook on the loop. Do this for both sides. Now the door should slide easily into the slots. Once in the slots, push down on the hook piece and release the loop. Push the loop back in place along the bar. Hopefully this does the trick for you, it did for me.
1/12/2022 4:13:31 PM • Kenmore Elite... • Answered on Jan 12, 2022
Enmore refrigerator model 795.71013.010 ice maker
michael masters is not giving you the proper info. i realize this is from a few years ago but i have to call out a dumb comment when i see it. he told you how to check a whirlpool ice make rand not an lg style ice maker. that you have with an 795 source refrigerator. sorry the he gave you the wrong info. if after 4 years you are still needing help, please respond and i will help you.
7/11/2021 11:15:02 PM • Kenmore Elite... • Answered on Jul 11, 2021
Water will not come out of the door dispenser
have you replace water filter ..... an easy test go to back of refrigerator where waterline goes int fridge and revers wires for icemaker and water dispensor and now use water dispensor it should put water into icemaker that will tell u that the switch to dispensor is working and you have a bad watervalve needs replacesed
7/2/2020 7:34:51 AM • Kenmore Elite... • Answered on Jul 02, 2020
2answers
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
6/13/2020 6:45:52 PM • Kenmore Elite... • Answered on Jun 13, 2020
Ice maker is not making ice
Ted,
The arm should be down. The down position applies power to the control module... when the arm is up power is off. It's the opposite of a light switch.
SG
4/28/2020 11:25:55 PM • Kenmore Elite... • Answered on Apr 28, 2020
10answers
Kenmore Elite Refrigerator error er dh
Great advice from medeer, I had the same ER DH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel. I accessed it by removing the freezer door, all components inside the freezer, and the tracks mounted on the sides of the freezer. Be careful when removing the white panel because a fan is mounted to the left side of the white panel and plugs into the back left side of the freezer compartment.
Found the green technical data sheets under the refrigerator in a small plastic bag near the front.
My refrigerator is 20 months old, just a few months past the warrentee,
4/2/2020 8:29:14 PM • Kenmore Elite... • Answered on Apr 02, 2020
2answers
Kenmore elite refrigerator alarm keeps going off
you have to send model number,on some bottom mounts there is a metal striker on the door that hits the switches,sometime that gets bent back,all you have to do is readjust the striker by bending it if screws aren't loose but i don't know what kind of bottom mount you have
11/6/2018 8:37:40 PM • Kenmore Elite... • Answered on Nov 06, 2018
2answers
Kenmore Elite - bottom Freezer - water leak from refrigerator
Found this solution on another site. http://davesgarden.com/community/forums/p.php?pid=6759829
5/19/2018 7:44:14 PM • Kenmore Elite... • Answered on May 19, 2018
How do i turn the demo mode off of my Kenmore Elite freezer
On one model you do the following: To get it out of the demo mode, press and hold the "up" and "set" pad for 10 seconds.
4/24/2018 4:45:24 PM • Kenmore Elite... • Answered on Apr 24, 2018
Why is ice frozen solid in the bin?
The ice could be caused by a partial thaw such as a power failure. To open bin unplug unit. Get lots of towels and a wet Vac if you have one. The use of these will become obvious shortly. Open the door and put a fan blowing on it, the same type of fan we use when it is hot to cool down. Then wait in time it will start thawing. This would also be a good time to clean it inside, you probably were putting that off. When totally thawed and dry start it up and keep an eye on it for a few days it will probably be ok. If not you have a clean unit to try some of the other suggestions.
4/16/2018 8:06:48 AM • Kenmore Elite... • Answered on Apr 16, 2018
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
1,248 questions posted
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
water leaking into freezer
  • Refrigerators
