20 Most Recent Zeiss Humphrey 740 Visual Field Analyzer Questions & Answers
Why does my zeiss humphrey visual field machine keep shutting down?
Sounds like a heat, thermal issue. You may have a non- functioning cooling fan somewhere inside. There are several of them so don't be fooled if you hear one of them running. Same issue happens with CPUs on PC computers. Will suddenly shut off if too hot.
4/7/2019 5:28:09 PM • Zeiss Humphrey... • Answered on Apr 07, 2019
Why does humphrey visual field analyzer beep when i turn it on?
The trouble is with the CPU. It needs to be replaced
9/5/2018 8:57:52 PM • Zeiss Humphrey... • Answered on Sep 05, 2018
Why no blind spot dectected
The two most common problems when trying to find a blind spot are: A.) Forgetting to patch the eye, and B.) Choosing the correct eye in the machine itself.
6/23/2016 1:41:57 PM • Zeiss Humphrey... • Answered on Jun 23, 2016
How do I hook my external laser printer to my humphrey 740?
In the user manual they list some compatible printers that have a 25 pin parallel connector. We use Lexmark Optra E312L with good results. Once you hook it up, you have to go into one of the setup menus to port it over. The user guide tells the procedure.
7/27/2015 8:45:25 PM • Zeiss Humphrey... • Answered on Jul 27, 2015
Zeiss humphrey system startup state 19
I believe "state 19" is a weak main illumination bulb. Not sure if it's the same on your 740, but that's what the problem was with our 750i. Even though the bulb appears to be working, they dim over time and won't pass the start up calibration checks. On ours, there is a round access panel on top of the unit to service this bulb. Just be careful removing the bulb and don't bump any of the clear optical wheels. Part # 2660021106082 (for 750i. not sure about 740) Call Zeiss to confirm. Realize this is an old post so info is for future readers.
7/27/2015 8:22:20 PM • Zeiss Humphrey... • Answered on Jul 27, 2015
CAN THE LIGHT BE TURNED ON IN THE ROOM WHERE THE TESTING IS DONE?
Yes it affect all tje instrument calibration when it is turn on, and when you have patient test the result is afected because the patien has light for the bavk and he is not able to see all the diferents type of lights
10/30/2014 6:46:34 AM • Zeiss Humphrey... • Answered on Oct 30, 2014
How do I fix the pointer on the touchscreen to be where you touch
You sjould press the patient button and the same time turn it the instrument on keep in button press until you see in tje display the calibration message of the touchscreen
10/30/2014 6:42:41 AM • Zeiss Humphrey... • Answered on Oct 30, 2014
2answers
Printer out of paper
erro 99
10/1/2014 5:22:35 PM • Zeiss Humphrey... • Answered on Oct 01, 2014
2answers
Why won't my printer work if the machine gets too hot?
is the cooling fan turning?
10/1/2014 5:21:16 PM • Zeiss Humphrey... • Answered on Oct 01, 2014
How can I fix my screen ,will not show anything on the field analyzer 740i? Help please
Did you move the brighness control. It is on the right side of the equipment. If not, it could be the video board inside of the equipment
9/10/2014 5:09:28 AM • Zeiss Humphrey... • Answered on Sep 10, 2014
How can I turn off the zeiss Humphrey? only from the shut down button or there is a function from the software?
This is a brand name, not a specific device and model. That said, here is a page describing mode switch in the setup screen using the touch screen for a specific device. I assume a touch screen would have an icon for turning a device off. Zeiss HUMPHREY 720i User Manual System Setup
6/16/2018 5:01:20 PM • Zeiss Science &... • Answered on Jun 16, 2018
2answers
What CMOS-battery goes into the Zeiss Visucam lite (build 2006)?
The battery is soldered to the CPU. People from Zeiss Germany said that it needs to replace all the CPU. Now a days there is no longer spare parts for that instrument. I recommen you just change the day and time each time you turn it on
1/5/2017 8:03:48 AM • Zeiss Science &... • Answered on Jan 05, 2017
We have a Zeiss Visucam Pro NM and are having problems with the program booting up on the computer. Sometimes unpluggin the power source will temporarily fix the issue, but it will rarely boot up on
Unfortunatly you should contact Zeiss representative for load again the completecomplete Visucam programprogram.
10/1/2014 5:35:47 PM • Zeiss Science &... • Answered on Oct 01, 2014
Have an aus Jena Laboval 4. Power supply is
This is very funny. I was just looking to find a similar solution for my laboval. Haven't measured it yet, but it keeps blowing the light bulbs. Do you run it at 110 or 220V?
5/19/2013 9:12:39 PM • Zeiss Science &... • Answered on May 19, 2013
Compare Apex Practitioner Microscope v C & A Scientific MFL-06 My First Lab Duo-Scope?
You are probably qualified by now but you question was resurrected by and AI Bot. https://www.google.com/search?q=Apex+Practitioner+Microscope+vs+C+%26+A+Scientific+MFL-06 ..
12/30/2023 9:34:23 PM • Science &... • Answered on Dec 30, 2023
Little Sister 3 Autoclave is displaying FILL but does not actually fill and goes no further. What can I do?
Technical Manual and other suggestions. Professional machines really need professional service as the repair is very specialized, and the dangers of using incorrectly sterilized tools injurious to health.
T echnical Manual
Frank's Hospital Workshop http://www.frankshospitalworkshop.com > Esch... The SES Little Sister 3 is a portable electrically operated steam autoclave suitable for the sterilization of unwrapped metal instruments and utensils. 4. The ... 47 pages
Watch out for These 7 Common Autoclave Problems
Consolidated Sterilizer Systems https://consteril.com > common-autoclave-problems 1. The sterilizer won't reach the temperature set-point. · The steam generator is need of repair. · There is a clog in the chamber drain (i.e. check the chamber ... Missing: Sister ‎' Show results with: Sister
11/19/2023 6:33:32 PM • Science &... • Answered on Nov 19, 2023
Zeiss Humphrey 740 Visual Field Analyzer Logo
41 questions posted
Top Zeiss Science & Laboratory Experts
Aron
Don A
Don A
Eliuska Castillo
Level 1 Expert
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
View Most Popular
  • Zeiss Science & Laboratory
Most Popular Question
zeiss humphrey system startup state 19
  • Science & Laboratory
