20 Most Recent
Ricoh Aficio 2022 All-In-One Laser Printer Questions & Answers
Error code SC 565 Ricoh MP 2550
SC565
*Heat lamp consecutive on error - Broken main fuser connection
*Heat lamp consecutive on error - Check HR thermistors with SP1-106 001 (ctr) and 002 (ends)
*Heat lamp consecutive on error - Heat roller lamp defective
*Heat lamp consecutive on error - Power Supply defective
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
I have had this aficio
Does the copier have a printer /scanner sd card installed and a network card installed in the machine as this is the best option to use the machine as a printer
Ricoh aficio 1022 all-in-one error code sc542
Fusing temperature warm-up error
The fusing temperature does not reach
the standby temperature within 20
seconds after the main switch is turned
on.
• Fusing thermistor defective or out of
position
• Fusing lamp open
• Fusing thermostat open
• Power supply board defective
• Poor connection of the fusing unit
It could need a new thermistor
SC542
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Error sc542 service
SC 542 Fusing temperature warm up error.Fusing lamp defective,poor fusing unit connector,thermistor warped or broken,thermostat has tripped,power supply defective.After verify the componenets try reset the error.Enter in service mode:Press the yellow key and press 107 and keep pressed the stop key 3 second.Touch the SP window on screen open the front door and turn OFF the copier.Wait 1 minutes ,close the front door and turn ON the copier.If the error code persist change the upper fuser roller and the thermistors.
Error sc548 aficio 1022 ricoh
if the above solutions failed, ask a technician to clean the thermistors, as toner build up on them and then give you the same code, have also found that power surge or power failure also cuase this code to come up repeatedly
My printer multifunction Aficio sp C240sf show the
For this model specifically, the following will get you into service mode.
Hit "Clear / Stop" Buttom then "107" then hold down "color print" buttom for some sec then you are in service mode
If that doesn't work, you can also use Clear/Stop,1,0,7, Clear/Start.
Each key should be pressed and held until you hear a beep
