20 Most Recent Ricoh Aficio CL3500N Laser Printer Questions & Answers
2answers
SC 441 Alert, Richo Aficio CL 3500N
I have run into this several times with these printers. In every case, it has been the CMY PCU. These run about $300.
I have read that by cleaning the PCU, you can get it to work sometimes. So far, I have not been lucky enough for it to work.
8/5/2021 12:10:15 PM • Ricoh Aficio... • Answered on Aug 05, 2021
Aficio mp171 toner error even after installing a
Unplug unit for a rest
3/31/2019 8:55:11 AM • Ricoh Aficio... • Answered on Mar 31, 2019
4answers
Ricoh Aficio Color Registration Error
One of our Ricoh CL3500N printers- less than a year old- gave us a "color regist error" after changing the transfer belt.
Ran the "adjust color regist" without results. It would just finish and pop back up with the same error.
Color test page printed no color, just BW
I reseated everything, and even replaced the PCU without positive results.
A couple hours later I went back, took everything out (be sure to keep the pcus out of the light!), and vaccuumed the heck outta that printer.
For whatever reason- maybe there was a chunk of toner hanging out, maybe I knocked something loose or back in place, whatever- but when I put all the parts in and turned it on, the error was gone and color printed great!
10/8/2018 1:51:27 PM • Ricoh Aficio... • Answered on Oct 08, 2018
2answers
Ricoh does not print it shows the printer sign but does not print
Make sure drivers are installed
4/18/2018 9:44:55 PM • Ricoh Aficio... • Answered on Apr 18, 2018
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
2/24/2018 6:42:45 PM • Ricoh Aficio... • Answered on Feb 24, 2018
3answers
I have a ricoh aficio mp c3500 that has sc 792 error.
possible toner pump
10/6/2017 1:13:37 AM • Ricoh Aficio... • Answered on Oct 06, 2017
2answers
Where do dispose of full toner waste bags?
It depends on where you live.
Do a Google search for " what's the best way to dispose of full toner waste bags?" And add your city,or state on the same line. It will return a list of places to recycle the toner.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
9/25/2017 7:46:26 PM • Ricoh Aficio... • Answered on Sep 25, 2017
2answers
SC 486 error
Este error is critico.
Aqui se encuentra el guia en Ingles:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/cl3500/cl3500en.htm
Impressadoras Ricoh de Puerto Rico:
Please remember to rate all users who assist you for free :) Jose Diaz I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
8/9/2017 10:51:04 AM • Ricoh Aficio... • Answered on Aug 09, 2017
2answers
Can anyone tell me how
Support information for your printer including drivers and software can be found here:
http://www.ricoh-support.com/enduser/downloads/advsearchresult.asp?type=download&ProdName=Printers
I believe the reset information you are looking for is on pages 49 and 50 of the Maintenance Guide PDF:
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=14386&ricohmodelid=6322&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%5Fv1oi%2Fhtml%2Foi%2Fre%2Fmodel%2Fcl3500%2Fcl3500en%2Ehtm
Trust this is helpful.
8/9/2017 10:47:58 AM • Ricoh Aficio... • Answered on Aug 09, 2017
How to reset a replace fusing belt unit error msg for ricoh mp c3502
Hi. It needs to be replace the Fusing Belt or na expecifique Fuse (if the belt is still ok). Enyway you need to have knowledge and tecnical skils for do it. It is not a simple procedure ever for a high skill tec
12/29/2016 9:38:46 AM • Ricoh Aficio... • Answered on Dec 29, 2016
2answers
HOW DO YOU RESET THE PCU ON RICOH CL3500N
I had the same issue with my CL3500N. I kept taking out and reinserting the color PCU with the same resulting error. However, I fixed my problem. My color PCU is now reset and printing Instructions on how I fixed the issue: 1) Turn off the printer and remove the color PCU from the printer 2) Look inside the printer where you removed the color PCU and you will notice three attach points (gears) that each of the three color PCU rollers connect to the printer. 3) Notice that each roller inside the printer has an arrow stamped in metal pointing toward it. On my printer, one at approximately the 2 o'clock position, 9 o'clock position and 3 o'clock position. 4) On the color PCU look at the end of unit that you insert into the printer. Notice the white female connectors on each of three rollers. Look closely and you will see that there are notches inside each connector (gears). One of those notches is longer than the others. 5) For each roller insert your finger into the white connector (gear) to rotate the roller so the long notch aligns with the arrow inside the printer. Be careful not to touch the photo sensitive area of the roller. 6) Insert the color PCU into the printer and turn it on. May need trial and error to align the notch correctly, but it certainly worked for me.
7/28/2016 2:55:19 PM • Ricoh Aficio... • Answered on Jul 28, 2016
2answers
Sc491 error on ricoh MPC 3500
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
 Defective drum unit or development unit
 Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
12/8/2015 1:27:27 AM • Ricoh Aficio... • Answered on Dec 08, 2015
Aficio cl3500n error code SC411, the printer comes
I remember a discussion on this code in an old thread somewhere. The agreed solution was to replace the whole transfer roller assembly because of a broken contact terminal in the discharge plate housing. I'd probably try that before a high-voltage board.3 For more help visit cbr tech solutions
11/23/2015 3:54:47 PM • Ricoh Aficio... • Answered on Nov 23, 2015
All my colored prints have 2 one inch strips of faded color. What do I need to do?
First tray printing a black and white copy to see if you get same quality problem then try each individual color. If it shows on each copy then check The transfer belt Assy . If it only shows on one color then would be a drum unit or could be toner on laser shield glass . Other thing stop it during copying process and see where it's coming from look at drums and see if that shows up on them
7/11/2015 11:11:36 AM • Ricoh Aficio... • Answered on Jul 11, 2015
What is causing my Ricoh CL3500N to allow vertical streaks of faded color on my copies?
This is usually caused by defective, or empty, toner cartridges. A good cleaning and replacing the old waste toner drum as will as the defective cartridge with a certified manufacturer's cartridge usually fixes the problem.
4/7/2015 11:00:31 PM • Ricoh Aficio... • Answered on Apr 07, 2015
Error code sc411
post
3/21/2015 1:20:11 PM • Ricoh Aficio... • Answered on Mar 21, 2015
Ricoh Aficio CL3500N Laser Printer Logo
384 questions posted
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
error sc 542
  • Office Equipment & Supplies
