20 Most Recent Dyson Air Multiplier 10" AM01 Bladeless Fan - Satin Iron/Blue Questions & Answers
2answers
Dyson fan not turning on
Hi there, it's Jack at Dyson. If your Dyson fan isn't turning on at all, it's worth double-checking it in a different power socket, just to ensure it's not the socket itself which is at fault. If your machine has a plug which includes a fuse, we'd also recommend checking this. If your fan still has no power when plugged in, or if the on/off switch LED light flashes when pressed, I'd encourage you to get in touch with us directly so we can provide further assistance. If a replacement part is needed we can also confirm if this is covered under our 2-year guarantee. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
1/14/2022 6:41:46 PM • Dyson Air... • Answered on Jan 14, 2022
4answers
Dyson bladeless fan not working. Lights on - nothing else
Dyson are over price made in china product and has lots of problems buy cheap regular fan
8/10/2021 12:53:26 PM • Dyson Air... • Answered on Aug 10, 2021
Dyson bladeless fan circuit burned out
First, you need to make sure that the faulty component is the ceramic capacitor. Then check to see if it's broken. Use the multimeter and read the voltage on the capacitor leads. The voltage should read near 9 volts. The voltage will discharge rapidly to 0V because the capacitor is discharging through the multimeter. If the capacitor will not retain that voltage, it is defective and should be replaced. (Source:https://www.apogeeweb.net/electron/what-are-ceramic-capacitors)
6/8/2021 8:57:12 AM • Dyson Air... • Answered on Jun 08, 2021
2answers
Why wont my dyson fan oscillate?
Hi there, it's Jack at Dyson. Your Dyson Air Multiplier AM01 desk fan should oscillate when you press the oscillation button on the base: 14be1ec2-0973-43bb-8dc5-8baab56cfe14.jpg If you find that it's not oscillating when this is pressed, we'd need you to contact our Support team directly - we can confirm if we're able to resolve this for you under our free 2-year parts and labour guarantee. You can reach us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
1/20/2015 9:34:04 AM • Dyson Air... • Answered on Jan 20, 2015
My Dyson Bladeless Fan/Heater is displaying E7 after a few minutes of running and then shuts down? It is brand new (a couple of months old) and been run about 3 times.
Hi Michelle, it's Jack at Dyson. If your AM05 Hot + Cool heater is displaying the E7 error code, the best course of action is to contact us directly for further assistance. To diagnose the cause of the issue we would need to understand more about how the heater is being used - we should also be able to suggest a suitable resolution. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We'll look forward to speaking with you.
12/9/2014 12:29:03 PM • Dyson Air... • Answered on Dec 09, 2014
Have a Dyson fan, less than 1 year old and has been working all winter and now need it to cool, just won't start
Still under warranty? Dig out the receipt!
10/9/2014 10:32:43 AM • Dyson Air... • Answered on Oct 09, 2014
How does a bladeless fan work
The air is drawn in by a fan in the base and then directed up into a ring. It comes out of a crack all around the ring and passes over a shape like that of an aircraft wing. Industrial designer Sir James Dyson named his fan the Air Multiplier
8/10/2014 12:24:04 PM • Dyson Air... • Answered on Aug 10, 2014
Dyson AM01 fan can not on
Hi David, it's Jack at Dyson. If your AM01 Air Multiplier desk fan doesn't seem to run at all, we'd appreciate the opportunity to take some further details - many issues are easily resolved with some troubleshooting checks over the phone. In the event that we're unable to resolve the issue, we can confirm if a repair or replacement is covered under your machine's 2-year warranty. You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
3/11/2014 4:41:09 PM • Dyson Air... • Answered on Mar 11, 2014
0answers
Not blowing air
Be the first to answer 2/23/2013 8:30:13 AM • Dyson Air... • Posted on Feb 23, 2013Be the first to answer
How do I fix F2 error on Dyson AM08 Pedestal Cooling Fan
To fix the F2 error on the Dyson AM08 Pedestal Cooling Fan, you must try resetting the fan by unplugging it from the power source for 2 to 3 minutes and then plugging it back in , it can work properly.
6/21/2023 5:42:40 PM • Dyson Dryers • Answered on Jun 21, 2023
C1 error code on dyson pure hot+cool
The C1 error code on the Dyson Pure Hot+Cool indicates a communication issue between the control board and the motor. Here are a few steps you can take to try and resolve the issue:
  1. Turn off and unplug the machine for at least 10 seconds, then plug it back in and turn it on again. This can sometimes reset the control board and resolve the issue.
  2. Check the filter and make sure it is clean. A dirty filter can cause the machine to overheat, which can trigger the C1 error code.
  3. Check the air intake and make sure it is not blocked. If the air intake is blocked, the machine may not be able to cool properly, which can cause the C1 error code.
  4. If none of the above steps resolve the issue, the problem may be with the control board or motor. In this case, it is recommended to contact Dyson's customer support for further assistance. They may be able to help you diagnose and resolve the issue, or recommend repair options if necessary.
2/27/2023 11:35:12 PM • Dyson Dryers • Answered on Feb 27, 2023
H2 error code on Dyson hot/cold fan unit.
what is the question?
7/10/2021 10:18:43 AM • Dyson Dryers • Answered on Jul 10, 2021
Dyson Am04 model no longer turns on due to a power surge. What part is required to fix it? TIA.
First thing is to check the wall socket. Use a desk lamp or something similar and plug it into the socket you use for the heater. If the lamp works so does the socket. Next check the fuse. UK machine have a fuse in the plug, other countries use different systems. If all these check out OK the surge may have damaged a circuit board inside the heater. Only a Dyson specialist could help you with that.
8/17/2020 3:11:16 PM • Dyson Dryers • Answered on Aug 17, 2020
DYSON AM08 PEDESTAL FAN HAS OPERATED FLAWLESSLY FOR TWO YEARS ! TODAY I STARTED IT , IT RAN AS USUAL THEN QUIT AFTER A MINUTE. I TRIED AND SEARCHED FOR A CAUSE FOR AN HOUR FOUND NOTHING UNUSUAL. WHAT COULD BE WRONG?
Probably the bearings are dry. remove the fan and housing to get to the shaft and oil it. The circuit breaker is shutting it off because it is drawing excessive current.
9/24/2019 8:58:41 AM • Dyson Dryers • Answered on Sep 24, 2019
My dyson hot and cold fan is displaying code C2 and won't turn on or off
quote from amazon site***Mine also showed H2. I had a suspicion that it was the remote causing it. Changed the remote battery (CR 2032), turned on the heater and let it circulate for 3 minutes, then I went and tested all remote buttons. It worked! No more H2 error code! Amazon Customer ยท September 11, 2018
8/30/2019 6:28:22 AM • Dyson Dryers • Answered on Aug 30, 2019
Dyson Air Multiplier 10" AM01 Bladeless Fan - Satin Iron/Blue Logo
11 questions posted
Top Dyson Dryers Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
View Most Popular
Dyson Dryers
  • Dyson Dryers
Most Popular Question
goldair bladeless fan unused in
  • Dryers
