20 Most Recent Konica Minolta Di1611 Questions & Answers
3answers
I can't find drivers for
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
10/28/2011 12:37:58 PM • Konica Minolta... • Answered on Oct 28, 2011
0answers
How to Solve C 3502 error code in konica Minolta c 6100 1100 1085 6085
The C 3502 error code in Konica Minolta c 6100, 1100, 1085, and 6085 machines is related to the fusing unit. The error code indicates that the fusing unit is not heating up correctly. There are several reasons why this error code might appear, including a malfunctioning thermistor, a broken fuser heater lamp, or a damaged fuser thermostat . A video: how to solve C 3501 3502 3503 3504 3505 3506 error in konica minolta 6500 6501 6000 7000 - YouTube Turn off the machine and unplug it from the power source. Remove the fusing unit from the machine. Check the thermistor and fuser heater lamp for any damage. Replace the damaged parts if necessary. Reinstall the fusing unit and turn on the machine. If the error code persists, it is recommended to contact a Konica Minolta service representative for further assistance
11/20/2023 4:33:49 PM • Konica Minolta... • Answered on Nov 20, 2023
Konica Minolta Bizhub C364E.
Question edited to toss in some CAPS. Not sure what you mean by 'on second fin'? Common issue https://www.google.com/search?q=Konica+Minolta+Bizhub+C364E+Stuck+booting+up ..
9/12/2023 7:28:21 PM • Konica Minolta... • Answered on Sep 12, 2023
Konica Minolta C6501 Tech Support.
We are FIXYA, we aren't Konica Support. We just have a Konica Minolta section for handy sorting of questions. Firmware and Support are in this link. Contact them direct via phone, email or chat options. https://www.google.com/search?q=konica+minolta+c6501+firmware+download ..
1/20/2023 9:14:58 PM • Konica Minolta... • Answered on Jan 20, 2023
Need to change scan to email address on Konica Minolta Bizhub C351
This could be related to your browser. One way to find out is to try the page on a different browser. Some other options are Firefox and Chrome. If it works on a different browser and you would like to continue using your original browser then you could try and clear the cache on the browser and try again. Which browser are you using and have you tried a different one? Let us know and I hope it works for you soon.
6/15/2022 1:53:44 AM • Konica Minolta... • Answered on Jun 15, 2022
I have an error code of c 5360 of konica minolta 368
I searched the internet using https://www.google.com and found the following result, that may require a technician to resolve: https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20C368&code=C5360
Code
C5360
Description
Clean unit fan failure to turn (When CU-101 is installed). The fan lock signal remains HIGH for a predetermined continuous period of time while the fan is turning.
Causes
• Exhaust fan/1 (FM14) • Exhaust fan/2 (FM15) • Suction fan (FM16) • Clean unit drive board (CUDB) • MFP board (MFPB)
Remedy
1. Check the connector between CUDB CN1-MFPB CN32E for proper connection and correct as necessary. 2. Check the connector between FM14-CUDB CN3, FM15-CUDB CN2, FM16-relay CN183-CUDB CN4 for proper connection and correct as necessary. 3. Check the fan for possible overload and correct as necessary. 4. FM14, FM15, FM16 operation check • Load check: Check code42, Multi code 4 • Control signal: CUDB CN3 (FM14), CUDB CN2 (FM15), CUDB CN4 (FM16) • Location of electrical component: 14-X 5. Replace the defective fan. (FM14 / FM15 / FM16) 6. Replace CUDB. 7. MFPB ICP14E conduction check 8. Replace MFPB.
2/21/2019 10:32:05 PM • Konica Minolta... • Answered on Feb 21, 2019
I have an error code of c 5360 of konica minolta 368e
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall. Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed. Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed. If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
2/19/2019 8:27:22 AM • Konica Minolta... • Answered on Feb 19, 2019
Aoc tft20w90ps driver
Aoc tft20w90ps driver? This trouble maybe power supply or inverter boards is defective. first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts if you have any question,please let us know email:[email protected],we sincerely hope we can help you! you can also check this boards whether suit you: 8921MYD1 715G2892 2 3 AOC ADTV8921MYD1 Power Supply Backlight Inverter for...
1/25/2015 9:31:41 AM • Konica Minolta... • Answered on Jan 25, 2015
Bizhub c552 error c3b02
In all likelihood this is the IH power supply board. Not a difficult procedure but the board may be expensive. Can send through details if required.Cheers
8/4/2014 11:43:06 PM • Konica Minolta... • Answered on Aug 04, 2014
Computers & Internet Logo
10 questions posted
Top Konica Minolta Computers & Internet Experts
Don A
Don A
ADMIN Andrew
ADMIN Andrew
gnana0537
gnana0537
Level 1 Expert
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Computers & Internet
Most Popular Question
39 t find drivers
  • Computers & Internet
