2001 Yamaha V Star 1100 Classic Logo
Posted on Mar 14, 2010
Fluid capacities engine oil capacity rear wheel oil capacity & recommended types
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Mar 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
6325
Points
21
Just a bit over 3 quarts(w/filter change) 20/40w oil,200cc of 80/90gear oil for the rear(i prefer the Yamaha brand) also recomment new drain washers 214-1198-01-00
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 22, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2495
Points
1999 year fzr250cc Yamaha how many use the engine oil capacity & how many run km
2answers
What type of fluids oil Etc are used in a 1987 JD 210C?
Kathryn,
Fuel Capacity 23 gal 87 L
Hydraulic System Fluid Capacity 16 gal 60 L
Oil System Fluid Capacity 2.2 gal 8.5 L
Cooling System Fluid Capacity 4.2 gal 16 L
Transmission Fluid Capacity 1.8 gal 7 L
Feb 22, 2016 • Garden
3.8l awd. how much transmission fluid goes in to a completely empty system,and what type of oil for transfer case.
Reference: 3.3/3.8L Fluid Capacities & Specifications - The ...
forum.chryslerminivan.net/.../12671-Reference-3.3-3.8L-Fluid-Capacitie...
May 8, 2009 - 10 posts - ‎2 authors
FLUID CAPACITIES Fuel (Approximate) - 20 US Gallons (76 Liters) Cooling System* 3.3 and 3.8 Liter Engines - 13.23 Quarts (12.5 Liters) NOTE: - *Includes heater and ...1996 Chrysler Town & Country LX [Always and forever the favorite.] ... Does anyone know what the transmission fluid capacity is?
1998 CHRYSLER TOWN AND COUNTRY 3.3L 6-cyl Engine ...
www.amsoil.com/.../vehiclelookup.aspx?...1998+CHRYSLER+T...
Amsoil
2answers
1helpful
2answers
What type of GEARBOX OIL is recommended for my ford bantam 1.6 petrol rocam engine 2009 model? it has 200 000 kilos on
Castrol SMX-X would be a good oil for a gearbox with that amount of mileage and is a ford recommended oil
2answers
I NEED THE OIL CAPACITY FOR THE 35 MM FORKS ON A 1986 FXR TOURING MODEL.
The FXR had the same front fork tubes as the Sportster. Harley-Davidson Type "E" fork oil is recommended. The fluid capacity dry (after disassembly) is 6.4 ounces. The fluid capacity wet (drain and refill) is 5.4 ounces.
Good Luck
Steve
What is the oil capacity for a front & rear axle for a Jeep Grand Cherokee 3.0
FRONT AXLE ± 0.3 L (2 oz.)
C200F
1.7L (57.5 Ounces)
C200FE
1.7L (57.5 Ounces)***
REAR AXLE ± 0.3 L (2 oz.)
C213R
2.07L (70 Ounces)
C213RE
2.24L (75.5 Ounces)***
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
** Includes 0.9L (1.0 Quarts) for coolant reservoir.
***ELSD - add 118 ml (4 Ounces) of friction modifier.
Transfer Case (3.7L Engine)
Mopar® ATF+4 Automatic Transmission Fluid
Transfer Case (3.0/4.7/5.7L Engines)
Mopar® NV 247/245 Transfer Case Lubricant
Transfer Case (6.1L Engine)
Mopar® NV146 Transfer Case Fluid. Usage of other fluid/lubricants is NOT recommended.
Axle Differential (Front-Rear)
Mopar® Synthetic Gear & Axle Lubricant SAE 75W-140 (API-GL5) or equivalent with friction modifier additive.
3helpful
Can you advise the oil capacity of automatic Gearbox Transmision
For 2004 BMW 745i, (E65 & E66 type), the oil capacity of automatic Gearbox Transmision, (GA6 HP26Z type), is 9.0 litres.
Oil type: Automatic Transmission Fluid (ATF) Shell M1375.4
Please rate my response. Thanks!
7helpful
2answers
Fluid capacities and fluid specs
2000 TOYOTA TACOMA 2.7L 4-cyl Engine Code 3RZ-FE
Engine Oil Grade 1......API* All TEMPS......5W-30 Optional ..10W-30
Engine, 2WD, with filter..........5.5 liters
Engine, 4WD, with filter..........5.4 liters
Manual Transmission,......GL-5/ GL-4 All TEMPS......75W-90
Automatic Transmission,A340E......AF3 / A43D......AF3
Differential, Front/ Rear W/ ADRD......GL-5 ALL TEMPS......75W-90
Differential, Front Less ADRD......GL-5 ALL TEMPS......80W-90
Transfer Case,......GL-4/GL-5 ALL TEMPS......75W-90 Gear oil.
Capacity:
Cooling System, Initial Fill..........8.5 liters
Automatic Transmission, A340E Initial Fill..........1.6 liters
Automatic Transmission, A340F Initial Fill..........2 liters
Automatic Transmission, A43D Initial Fill..........2.4 liters
Automatic Transmission, Total Fill
4 speed A340E..........7.2 liters
4 speed A340F..........10.1 liters
4 speed A43D..........6.5 liters
Manual Transmission, ..........2.5 liters
Differential, With ADRD Front..........1.2 liters
Differential, Without ADRD Front..........1.1 liters
Differential, 2WD V6 Rear..........2.6 liters
Differential, 4WD Extra Long Rear..........2.5 liters
Differential, Short WB With LSD Rear..........2.7 liters
Differential, Short WB Without LS Rear..........2.6 liters
Transfer Case, Electronic..........1.2 liters
Transfer Case, STD..........1 liters
1helpful
2answers
What is oil capacity for a change with filter on my Sienna? How about the trans fluid too?
Vehicle: Fluid Type Specifications
System Specifications
Automatic Transaxle Capacity (Drain & Refill) ............................................................................................................................... up to 3.5L (3.7 US qt.)
Fluid Type ............................................................................................................................................................. ATF D-II or Dexron-III - Dexron II (r)
Audi A4 1.9 TDI power steering oil type and capacity
Power steering fluid level checking:
- vehicle stationary
- front wheels in straight ahead position
- engine at normal operating temperature
- remove cap with dipstick from expansion tank and wipe off
- reinstall cap with dipstick and remove again
- fluid level between "min" and "max" markings
- top off with G 002 000 hydraulic oil if necessary
Power steering system capacity is around 1 liter, but it is not necessary to periodic change the hydraulic oil!
If oil level has dropped to the "min" marking, check power steering system, including hoses and lines.
It is not enough simply to top off the hydraulic oil !!!
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
