Washing Machines Logo
G
Glenn D Knight Posted on Oct 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WM2487HRM Hot water will not fill, soleniod good, single plug with three wires.
Swapped plug from cold water valve to hot water valve and it flowed water without problem. Put the plug back on for the hot water solenoid and all I get is click and humm when the solenoid is being selected. What is up stream from the solenoid electrically? ***UPDATE*** Well, $131 dollars later and a new PWB and the washer is back to running normal. Turns out that my suspicion was right. The PWB was not providing the signal to the hot water solenoid.
Gerry Harvey
Level 3:
Genius:
  • Washing Mach... Master 1,482 Answers
  • Posted on Oct 21, 2017
Gerry Harvey
Level 3:
Genius:
Answers
1482
Questions
0
Helped
379226
Points
4533
Is the water off perhaps.Fact the solonoid hums sounds like it.
Testimonial: "Perhaps I should have prefaced my question with a bit of background. I am a retired veteran with over 40 plus years of electronics experience. The first thing I swapped out was the solenoid, after checking both the debris screen and the water flow from the hot water feed line. I was hoping that before I went after the PCA board that someone might have had experience on the circuit level so I could go after the component versus the card (since they aren't manufactured any longer). Since the other solenoids are working and they all share a return line (daisy chained) to the PCA, I figure it has to be the control signal coming from the board."
5 Related Answers
Anonymous
  • 686 Answers
  • Posted on Apr 18, 2009
SOURCE: Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Anonymous
  • 1776 Answers
  • Posted on Jul 19, 2009
SOURCE: Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Anonymous
  • Posted on Jan 14, 2010
SOURCE: My Bosch wfl2060 begins filling with water - only
The hot water fill valve was replaced and not it seems to work well!
beltronic205
Gerry Harvey
  • 1482 Answers
  • Posted on Feb 08, 2010
SOURCE: F&P GW611 with a cold water trickling in.
Check 1st if water is flowing well from the hose. hold it over the sink or bucket/if not could be faulty water valve..Put valves back to original as hot may have a reducer to cut down pressure hence the pulsing that you say...
Anonymous
  • 2468 Answers
  • Posted on Oct 20, 2010
SOURCE: I have a F $
if you have normal pressure just past the hot valve solenoid,check at the entry way to the dispenser at top of the tub where it enters or thye bleach dispenser door for a kinked or collapsed,hoses that handle hot water collapse (internally and you cant see this from outside the hose) after time
What does it mean when my lg tromm WM2487HRM front load washer slowly fills the tub with water when the washer is off?
most likely water fill valve is defective and leaking. hot water or cold water? replace which ever is leaking
3answers
Cold water isn't coming on, only hot?
Not sure what ur saying have u tried changing the hot cold hoses and see what happens? u may have a bad water inlet valve or a bad water temperature switch? first make sure ur getting hot from the house outlet, u can check with a multi meter for continuity to see if either is out
1helpful
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
1helpful
My Fisher and Paykel mw511 intermittently will not fill with cold water. The bowl spins slowly as if it should be filling with water and I can hear a pump but no water comes out. I swapped the hoses and...
Cold water valve problems with F&P machines are common. Replacing the cold valve is the most likely remedy.
It's not good policy to use the hot valve on the cold inlet because (we are told) they are different in their tolerance of high water pressure. (don't shoot the messenger!!)
As you've changed the valves, you've already seen that the problem can be removed...
Good luck.....Nomess
4helpful
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
1helpful
Hi there my hotpoint washing machinewma 54 fills up without the machine being on
Hello. your fill valve is faulty and needs to be replaced.
here is how the fill valve is supposed to work:
The fill valve--which is about the size of a coffee cup--is sometimes also called a "water inlet valve." It controls the entry of hot and cold water into the machine. The valve has three major components:
  • A hot-water solenoid
  • A cold-water solenoid
  • A mixing valve body
The inlet valve has three hoses connected to it, for :
  • The hot water from the house
  • The cold water from the house
  • The water directed into the washing machine's inner tub (either hot or cold, or both) to fill it with water
When electricity flows to one or both solenoids, water flows through the valve into the washing machine's inner tub. When the electricity stops, the water also stops.
1helpful
Hotpoint BWD129 - Wash temperature too high
Hello
Welcome to Fixya
My name is Huum,
Water temperature switch
The water temperature switch directs power to the valve. If there is no power getting to the valve, check the switch according to the wiring diagram for your machine.
Faulty Water Inlet Valve
The water inlet valve is the device that meters water from the supply lines into your wash tub. On domestic washers, there are two lines, one hot the other cold. These valves are susceptible to mineral build-up and sediment deposits. There are two common failure modes:
Failure Mode One: Valve will not open.
If you can verify that the solenoid on the valve body is receiving the requisite voltage and the valve will not open, then it is faulty. Since the solenoids operate independently, it is likely that one side of the valve will work and the other will not. This can produce strand results such as a very hot wash when warm is selected (due to no cold water). Or the reverse in that the wash water is cold when warm is selected. If mineral or hard water deposits are a problem, you may witness a substantial increase in the time required for the tub to fill. This is caused be a decrease in the flow ware of the valve.
Failure Mode Two: Valve opens but will not close.
This is verified by a valve that allows water to flow into the tub even though no power is being supplied to the solenoid. This one is usually quickly diagnosed when the machine begins to overflow and the power plug for the washer is disconnected from the wall. However, this will not stop the water from flowing into the machine. The water must be shut off at the wall. As with the previous failure mode, the variant of this failure mode is that it may take the valve a while to completely bridge the flow of water after the power has been removed from the solenoid.
How to Diagnose?
There are a couple of ways to diagnose a faulty valve. However, there is a simple test that one can perform that will usually let you know if the water inlet valve is faulty.
Scenario:
When set to cold wash and rinse, the unit will not fill. When set to warm wash and cold rinse the washer will fill with hot water only and will fail to rinse. This is a common scenario where the cold water side of the valve does not appear to be contributing to the fill, but the hot water side does. This symptom could be easily reversed where cold water is being supplied, but never hot water.
So, how can the problem be determined? It is as simple as switching the wire harness plugs on the hot and cold side. In the example above where the cold water is never being supplied, the symptoms would be the opposite when the wiring harnesses were switched. So the machine would produce only produce cold when warm or hot is selected. No water should be present when you select cold. This verifies that the timer, wiring and switches are all in working order. Assuming this tests checks out, you simply need to replace the water inlet valve.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Washer not filling
Hello yamamanot
Welcome to Fixya
My name is Huum,
You said, You did several loads of laundry yesterday but will not fill today or run.
Here are a common thing that cause this problem.
Washer will not fill!
How to Diagnose?
Scenario:
Thank You For trusting us with your guestion
Please remember to leave a rating before you leave!
All cycles run cold
Hello
Welcome.
How to Diagnose?
Scenario:
Recent Customer Symptoms:
I have a Kenmore Washing Machine. My question is if I set the washer on cold was and cold rinse it will not fill with water but if I set it on hot wash and cold rinse it will fill with Hot water and wash normally but when it comes to rinse with cold no water will fill and will go to the spin cycle assuming that it had filled with water. There is water in the cold water source. Any idea??? I was assuming the timer but not to sure.
Thank you , Huum
Please remember to leave a solved rating before you sign off !
Top Washing Machines Experts
john h
