20 Most Recent
Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15 Questions & Answers
Intuitive eco washing Machine says power cut and lights continually flash
Here is how I fixed mine using the knowledge of years of fixing things.
I grabbed the machine from the top with both hands and shook it off the floor very hard with a good thump X 2
I went to university for longtime to know this is how to fix it;
The circuit boards and sensors are not bad. It just after years of bumpy spin cycles there is a loose connection. This will shake the troublesome connection into a new position where it makes better contact.
It's temporary.
One day you'll have to open it and check all the connections are tight and clean.
Fisher & paykel mw511 pride
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
Code error 131.
Hi just read your posting.Error Code 131 is called REPETITIVE ROTOR POSITION SENSOR ERROR..The 3 reasons this fault is appearing is 1--the wiring to the rotor sensor is faulty.--2--the rotor sensor is faulty.--3-- the motor controller is faulty.If you have or can borrow an electrical test meter I can help you test the wiring but to test the rotor sensor you need a tester called RPS tester.Please reply on how you would like to proceed an I will help you as much as I can.
FP fault 43
code 43 is an out of balance switch problem.Once replaced, would fix the issue.
One trick that might work ;-
I unscrewed top cover, then unscrewed and lifted up the grey computer
cover. The balance switch is underneath on the right with a yellow and
white wire coming off.
I removed switch from clip and then
removed the wires/clips from contacts. There was definitely corrosion
on the contacts. I soaked switch overnight in vinegar. Then rinsed with
water. Then dried switch out for day.
Put it all back together and am now on second load of washing.
Thanks.
Needs Service code 136
136. (10001000) Motor Stall
The Motor Control Module has been unable to start the motor. Possible causes of this fault
are: Faulty motor harness, faulty or jammed motor, seized bearings or seals, faulty Motor
Control Module, faulty Rotor Position Sensor or harness.
Primary Source: Wiring.
Action: Measure/check the motor harness, connectors and motor for
discontinuity. This can be done by taking a resistance measurement
between phases of the motor harness at the Motor Control Module
end. Nominal resistance should be around 32Ohms.
Secondary Source: Motor.
Action: 1) Check free rotation of the agitator and basket by rotating by hand.
Bearings and seals may be seized.
2) Check the Rotor Position Sensor and associated harness for
water, mechanical damage or corrosion.
Tertiary Source: Motor Control Module.
Action: If the primary and secondary checks pass inspection, then replace
the Motor Control Module.
Bearings
I can talk you througt this in live chat, but you'd need to get a F&P Bearing replacement toolkit and seals and bearings and a new agitator shaft. cheers
Error code 43
Hi just read your posting.Error code 43 is called OUT OF BALANCE SWITCH ERROR.This means either your switch is faulty or your your control module is faulty.95 % of the time it is your switch which is located under the control module which is under the top panel.If you want I can guide you step by step in the replacement of this switch.Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Error code 37
I also got Error Code 37 at the end of a wash with the machine full of suds. I used the other information listed under this problem to establish that the pump was blocked, (no amount of hand-turning loosened the fan). After unplugging the machine from the wall, I removed the pump easily by unplugging the power and earth from the pump, pressed in a clip on the side of the pump to allow the whole pump to rotate and then pull out, (a bayonet type fitting). From where the pump came out from was a small piece of cloth and other gunk! I refitted the pump and reconnected the power and earth. The machine is now working happily again.
Hi I have a fisher
if it keeps filling until it floods the it has afaulty transducing which is locatedin the mainboard which will have to be replace
