Maytag neptune washer-washer works normally except at the end of the spin cycle when it should shut off, it does not.(happens in all timer modes) On light stays on, door lock light on, and after a couple of minutes timer will advance and start the wash cycle all over again. I can manually turn off washer. Only other thing I have noticed is after the spin cycle is complete, I turn off the machine manually, it takes several minutes for door to unlock and unlock light to go out.....if I reach in and rock the drum back and forth I can hear water sloshing.
D sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
just be sure when ordering htetimer you have the serial number as welll they have a few for this model and your serial will determine which oyu will need!
perahspd if its geting stuckin one position andnot moving that would be apossiblity, but the fact that it moves past a stop point nad begins a new cycle, id think the timer!
Will order a timer and see if it fixes it. THANKS
Thank You again for your help. Before I order the timer-since the washer will not turn off on any 'off' position on the the timer dial, is there any way to verify the timer is bad or could the machine control board be the problem not processing the signal from the timer?
OK, thanks
OK-I ordered a timer(exact part number replacement) Installed it, no help-same problem. " Washer works normally except when timer gets to any off position, washer does not turn off. It spins normally, after finishing spinning, door locked and ON light never go off. After approx. 3 minutes tub starts filling and cycle starts all over again."??????
