20 Most Recent Maytag MAH6700AWW Neptune Front-Load Washer Questions & Answers
4answers
What does the F30 code
The F30 error code indicates an issue/error with the Dispenser System. It occurs when the dispenser motor cannot be driven to its proper position.
12/5/2022 2:49:38 AM • Maytag... • Answered on Dec 05, 2022
2answers
Door opened while running. my fault. it's stopped, unlocked now, but full of water. How do I empty it.
Use a Wet and Dry vacuum and vacuum the water out, or use a Siphon hose.
10/15/2020 8:13:20 AM • Maytag... • Answered on Oct 15, 2020
2answers
Model MAH4000, will not spin out, door lock will
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
10/9/2019 1:18:47 PM • Maytag... • Answered on Oct 09, 2019
Neptune #MAH6700AAW will not drain, how to test control board?
Have you checked lid switch? If bad, unit will not spin and drain.
5/28/2018 12:49:54 AM • Maytag... • Answered on May 28, 2018
2answers
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues. First check that the drain pump, drain hose, and wall drain are free of debris. The washer may not spin properly if the drain system is not operable. Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash. If the washer hums but now drains, you fixed one issue. If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc... Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed! check all water outlets to make sure there is nothing blocking the pipes. you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
10/24/2017 12:16:20 PM • Maytag... • Answered on Oct 24, 2017
Why would my washer suddenly quit while draining between rinse and spin?
Always supply a model number, each model has it's own foibles. It is very hard to assist without full details, sorry.
10/3/2017 6:24:58 PM • Maytag... • Answered on Oct 03, 2017
0answers
0answers
How do I stop the error E2 code on my washer? I
The E2 shows that there is a motor problem. This can be caused by having an extra heavy load in the machine so take some out and try it. It can also be cause by any iof the buttons being stuck so make sure they are all 'free'. If this fails then you will need to have a new motor and call a repair man unless you can do the job yourself.
6/5/2016 10:16:35 PM • Maytag... • Answered on Jun 05, 2016
Unlocking a may tag door washer
Fuse open ... must meter all the fuses in the back. Use an ohm meter.
6/2/2016 7:08:34 PM • Maytag... • Answered on Jun 02, 2016
Did not drain. i replaced drain pump still does not drain
Could it be one of the valves? My LG front loader had problems with one of the electronic valves not opening and closing properly.
12/9/2015 4:18:14 AM • Maytag... • Answered on Dec 09, 2015
How to fix leak from soap dispensor
I assume you have water coming out of the dispenser and running down the front of the machine. You probably have a build up of soap powder in the water inlet and it is restricting the flow and backing up. Soap powder is only partially soluble in cold water and a residue of undissolved powder builds up over time, one of the reasons I use a liquid detergent. Remove the dispenser tray, it should pull out fairly easily with just a little resistance. Try and clear any blockages, hot water is best as it dissolves better. Clean the tray you have removed and re-assemble.
12/7/2015 4:57:12 AM • Maytag... • Answered on Dec 07, 2015
Why slow spinning?
a slow spin sometimes indicates that a out of balance switch might be malfunctioning
11/1/2015 10:26:11 AM • Maytag... • Answered on Nov 01, 2015
Maytag MAH6700AWW Neptune Front-Load Washer Logo
520 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
Neptune Maytag
  • Neptune Maytag
Most Popular Question
poaring water from soap dispenser
  • Washing Machines
