Cars & Trucks Logo
Anonymous Posted on Jan 05, 2013
Do I need to buy a luggage scales? My luggage overweight frequently.
  • Anonymous Oct 13, 2023
    Yes, you need. If your luggage tends to be frequently overweight, considering a luggage scale could be a practical solution. It's a simple tool that can save you from unexpected fees at the airport. Additionally, if you're looking for luggage scales or other travel accessories, you might want to check out Tote and Carry customer service . They have big choice of travel-related products and can offer recommendations based on your specific needs. Having a reliable luggage scale can make your travel experience smoother and more cost-effective.
Anonymous
Level 2:
New Friend:
  • Expert 29 Answers
  • Posted on Jan 05, 2013
Anonymous
Expert
Level 2:
New Friend:
Answers
29
Questions
Helped
4056
Points
147
It is often you may carry a lot of things in your luggage and thus when you are checking in at the airport, you have to weigh your luggage. If the luggage is overweight then one has to pay some extra money for it. So it is advisable that you would better buy luggage scales and weigh your baggage before going to the airport. This can help people save a lot of money and also help you in carrying the baggage easily.
Testimonial: "Thank you."
Melissa Blanco
Level 2:
Habit-Forming:
New Friend:
  • Expert 23 Answers
  • Posted on Dec 09, 2017
Melissa Blanco
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
23
Questions
33
Helped
8278
Points
146
I am a traveler and a luggage researcher I already spend 1.5 years on luggage I think I give you right information about this this topics. I have a blog about luggage seals and many information I think you visit this or read this site you will find your problem solution. Best Luggage sets. Best Carry On Luggage In 2017 15 Top Sold Luggage Of The Year
2003 town car trunk wont open with remote or button on door, only key?
Luggage Compartment Lid
The luggage compartment lid module receives a voltage signal from the driver door module (DDM) when either the button on the driver door trim panel, the keyless entry keypad, or the transmitter is pressed (twice on the transmitter). Voltage is then supplied to the luggage compartment lid latch, opening it. Using the luggage compartment lid key operates the latch mechanically, resulting in manual-only operation of the lid. There are two switches in the latch. One is monitored by the luggage compartment lid module to sense if the latch is closed. The other switch in the latch is monitored by both modules (LCM and luggage compartment lid module) and is used for disabling the anti-theft system, which is contained within the LCM. The luggage compartment lid module powers the lid motor to move the lid to the full-open position when it senses the latch has been opened. Optical sensors within the lid motor are monitored by the module to determine when to turn off power and which circuits should be powered or grounded to the lid motor. When one of the buttons is depressed with the lid open, the DDM sends a signal to the luggage compartment lid module which powers and grounds the correct circuits to the lid motor and lowers the lid until the latch closes. The module senses the latch closing through the lid latch switch that is monitored. At this time, the module powers the closing motor, slowly pulling the lid to a fully closed position. Two switches within the closing motor are monitored by the module to determine when the closing motor is fully down or up. The module has a vehicle speed output (VSO) (circuit 679) signal that is used to shut down the system if there is a VSO of approximately 5 kph (3 mph) or more. For diagnostics, the module uses the ISO-9141 circuit 70 that is included in the DLC (data link connector). Whenever battery power is lost to the luggage compartment lid module, luggage compartment lid motor or the luggage compartment lid closing motor; the system must be initialized.
NOTE: The luggage compartment lid motor is equipped with an optical sensor that the module uses to determine if the lid is closing on foreign materials based on lid speed. If the module detects this occurring, power and ground will be reversed to the lid motor and the lid will open.
  1. Verify the customer concern by operating the luggage compartment lid using the four different methods (driver door trim panel button, transmitter button, keyless entry keypad and key) to duplicate the concern.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Luggage compartment lid motor
  • Luggage compartment lid closing motor
  • Luggage compartment lid latch
  • Luggage compartment lid and hinges
  • Battery junction box (BJB) fuse(s):
    • 109 (40A)
    • 1 (30A)
  • Central junction box (CJB) fuse(s):
    • 30 (7.5A)
    • 14 (7.5A)
  • Circuitry
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step. Verify the two grounds (G204, G401) are clean, tight and free from corrosion. Remove and clean to make sure.
  1. Monitoring the PIDS in the luggage compartment lid module can verify the DDM is sending the lid-open signal to the lid module. They can also be used to determine if the latch switches, the lid switches and the lid motor sensors are all providing the luggage compartment lid module with the correct and necessary information to operate the system. The VSO input can shut the system down if there is a signal indicating 5 kph (3 mph) or more.
  1. If the electrical lid operation is ok, but the key is ineffective, refer to Section 501-14 .
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) located under the instrument panel and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
    • If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the DATA LINK DIAGNOSTIC TEST. If the diagnostic tool responds with:
    • CKT 914, CKT 915 or CKT 70 = ALL ECUs NO RESP/NOT EQUIP, refer to Section 418-00 .
    • NO RESP/NOT EQUIP for luggage compartment lid module, Go To Pinpoint Test A .
    • SYSTEM PASSED, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out the self-test diagnostics for the luggage compartment lid module.
  1. If the DTCs retrieved are related to the concern, go to the luggage compartment lid module Diagnostic Trouble Code (DTC) Index to continue diagnostics. For lighting control module (LCM) concerns, refer to Section 419-10 for a complete DTC index.
  1. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart. Luggage Compartment Lid Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU is Defective Luggage compartment lid module INSTALL a new luggage compartment lid module. B1359 Input Low When Key in RUN/START Position Luggage compartment lid module Go To Pinpoint Test A . B1551 Latch/Lid Release Circuit Failure Luggage compartment lid module Go To Pinpoint Test C . B2418 Sensor Power Short to Ground Luggage compartment lid module Go To Pinpoint Test B . B2419 Sensor 1 Invalid Luggage compartment lid module Go To Pinpoint Test B . B2420 Sensor 2 Invalid Luggage compartment lid module Go To Pinpoint Test B . B2421 Vehicle Speed Sensor Circuit Failure Luggage compartment lid module Go To Pinpoint Test C . B2522 Vbatt 1 Circuit Failure Luggage compartment lid module Go To Pinpoint Test A . B2552 Vbatt 2 Open Luggage compartment lid module Go To Pinpoint Test A . B2698 Vbatt 2 Circuit Failure Luggage compartment lid module Go To Pinpoint Test A . B2703 OPEN CLOSE SW Input Stuck Active Luggage compartment lid module Go To Pinpoint Test B . B2718 Lid Ajar Output - Short to Battery Luggage compartment lid module Go To Pinpoint Test B . B2721 Lid Ajar Output Circuit Failure Luggage compartment lid module Go To Pinpoint Test B . B2748 Drive Motor Open Circuit Luggage compartment lid module Go To Pinpoint Test B . B2755 Drive Motor Short to Battery Luggage compartment lid module Go To Pinpoint Test B . B2757 Drive Motor Output Short to Ground Luggage compartment lid module Go To Pinpoint Test B . B2825 Obstacle Detection Path of Decklid Luggage compartment lid module Go To Pinpoint Test B . B2876 Striker Drive Short to Battery Luggage compartment lid module Go To Pinpoint Test D . B2877 Striker Drive Output Short to Ground Luggage compartment lid module Go To Pinpoint Test D . B2905 Striker Motor Open Circuit Luggage compartment lid module Go To Pinpoint Test D . B2906 Striker Up SW Input Invalid Luggage compartment lid module Go To Pinpoint Test D . B2907 Striker Down SW Invalid Luggage compartment lid module Go To Pinpoint Test D . B2908 Latch SW Input Invalid Luggage compartment lid module Go To Pinpoint Test B . B2910 Striker Up SW/Striker Down SW Mismatch Luggage compartment lid module Go To Pinpoint Test D . B5131 Clutch Circuit Failure Luggage compartment lid module Go To Pinpoint Test B . C1123 Vehicle Speed Sensor Circuit - Fault Luggage compartment lid module Go To Pinpoint Test C . Do you know what diagnostic trouble code's are ? That would be the first place to start , checking for code's . An seeing how you probably don't have a ford IDS - scanner . your best bet mite be to take it to a qualified ford - lincoln dealer
2answers
Pneumatic trolley wheels for bag trolley. prices at bunnings?
Is this a golf bag buggy, or like a hand truck?
I needed new pneumatic wheels for a hand truck trolley, and it was cheaper to buy a new trolley from Supercheap Auto !!
Big B wasn't cheaper.
What is the luggage capacity in a 2004 model compared to 1997 v6 Suzuki Grand vitara
wow.
volume or weight?? and the word luggage means zero.
volume is stated, (WxL,H) and about 1000 lbs.
google the old sales brochures, they are easy to find
but... why?
USA CAR or not
if in USA why buy the dead car company here, , suzuki
they bugged out, chapter 11, and dont evens sell new cars.
nor easy to get part now due to massive dealership closures.
by a JEEP or RAV4 and avoid this POS, Suzuki.
TYRE PRESSURE
There are more overweight people in the United States than ever before. The same can be said for the entire world. In the United States alone, there are 210 million overweight people. That accounts for 70% of our population.
I created this report so that people like you, have a choice, maybe you like a particular way of losing Weight Loss Reviews, and these three products offer three different ways of doing just this.
http://eternitynaturalscleanse.com/nutra-forskolin/
2answers
How much should I weigh if I am 74 pounds and 56 inches
According to the BMI Chart you are underweight. Your BMI is 16.5. A healthy BMI is 20-22 or at your height 95-100 pounds.
This should not be taken as medical advice but only a general guide. Person who are athletic or weightlifters may have different results.
The BMI is an attempt to quantify the amount of tissue mass (muscle, fat, and bone) in an individual, and then categorize that person as underweight, normal weight, overweight, or obese based on that value. However, there is some debate about where on the BMI scale the dividing lines between categories should be placed.[2] Commonly accepted BMI ranges are underweight: under 18.5, normal weight: 18.5 to 25, overweight: 25 to 30, obese: over 30.
I need the boat and trailer (stock trailer) weight
Pull the trailer and boat to a scale and weigh it to get the exact weight. Most trucking companies,gravel yards, junk yards or even a state scale where they check for overweight trucks have scales to do that.
Sample complaint letter to AA
you need to post this on the correct site this is not it.
What do I need to consider when buying Motorcycle Luggage for long trips?
There are two types of luggage - hard vs soft. Whatever you decided which of the two it is highly recommended to have a tank bag when you're touring. This tank bag is ideal for the things like camera, money, passport etc.
Cheng Shin Motorcycle tires
2answers
Luggage cover missing needed to purchase a new one as it went missing, where and how much would it be?
check this out....
http://www.hyundaiaccessorystore.com/Hyundai_Tucson_Cargo_Screen.html
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
