20 Most Recent
Kodak EASYSHARE V1253 Digital Camera Questions & Answers
The camera switches on and
Hello
Actually there is a sensor responsible to tell the camera that the lens is out and ready to be used. And if the said sensor does not trip then the camera thinks that there is a prob. Try the following
1. Turn on the camera
2. Notice the movement of the lens as to which direction is it Turing while it is getting ready
3. try to pull the leans assy. a little outwords. But be gentle. Once the sensor has detected by the camera it will remain ON
Screen gone black
You might need new batteries, or the LCD panel might need to be replaced. The panels are available for 20-30USD
Kodak pink pictures
Check all the settings under menu / setup. Try a firmware update from Kodak support page, if no change camera will need service.
V1253 camera software download
You don't need any special software in order to use your camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
Replacement parts for a Kodak v1253 Camera
These parts could be difficult enough to obtain. You will need to put in a special order as these will not be carried in normal stock.
I have used these guys before for special orders. Try this email and hopefully you might just get a result
[email protected].
Hope this helps.
